Can you say "void your warranty"?
Are you saying that there's something in the plug itself that senses its temperature? If so, I guess I understand the tradeoff. But I don't like it.Then you'd have to hack off the 5-15 plug that contains the thermal protection, built into the EVSE. That's why I think leaving the EVSE unmodified is best![]()
And to answer your question about why GM doesn't provide 240V adapters like Tesla, it's because GM's infinite wisdom says Volt owners don't care about charging at L2 at home.![]()
I would have guessed the short pigtail was due to the New storage space that they made for the charging cable.Or it might just be that UL will not certify any such adapter and GM does not want to take on the liability. Ever wonder why the Pigtail on the charger is so short, maybe go check UL specifications.
And this EVSE is only UL certified to run at 120VAC (but I'm getting 125VAC from my outlets!) GM took on a helluva responsibility by supplying crappy Lear EVSEs to 2010, 11, 12, and 2015 Volts, too. Lear was cheap, Lear caused problems, Lear EVSEs got a ton of warranty recalls that cost GM money. Lear got the boot for the 2016 models and Clipper Creek came in and saved the day with a thermally protected plug. No more melty outlets or warranty claims due to faulty outlets.Or it might just be that UL will not certify any such adapter and GM does not want to take on the liability. Ever wonder why the Pigtail on the charger is so short, maybe go check UL specifications.
Since it appears that GM sub-contracted the design out to Clipper Creek, maybe GM themselves didn't realize it could operate either way?It doesn't seem like the question has been asked, so..
Why isn't GM marketing it as capable of 120/240v if it is fully compatible inside?
It would clearly be a huge plus to sales as one of the things turning a lot of people off it needing to spend another $500-1000 up front to be able to charge more quickly.
The three main power carrying wires are 16 gauge. The pilot wire is 18 gauge. And yes, 16 gauge is plenty for delivering 12A.ChrisTX, thanks for your work on this.
Did you confirm the gauge of the output cable? The stamp on the sheath looks like 18 gauge or maybe 16, it's hard to read. Are you be comfortable pushing 3kW down 18AWG wire?
10-30 is fine. It only uses ground for GFCI sensing.Thanks. One more question. My outlet is 10-30. Will this mod work with a hot-hot-neutral? I know it shouldn't make a difference as neutral and ground go to the same place in the electrical box anyways but I wanted to check to make sure you don't know of any issues.
Great work...10-30 is fine. It only uses ground for GFCI sensing.
Here's a picture of an adapter I made for 14-50:
Yes, the neutral is clipped. And yes, it's a 5-20R which also handles the 5-15P on the EVSE. I used it because it has bigger lug holes for the larger gauge wire and has better contacting internal blades for the plug bite.Great work...
2 questions, 1. Did you leave the neutral wire from NEMA 14-50p unused?. 2. The 5-20r on your adaptor is a 20amp, 125v, correct?
Wrong answer.And to answer your question about why GM doesn't provide 240V adapters like Tesla, it's because GM's infinite wisdom says Volt owners don't care about charging at L2 at home.![]()
That goes against everything GM has publicly said about only providing L1 EVSEs along with 3.3kW and now 3.6kW onboard chargers. They've publicly stated it's because customers don't care about faster charging at home. Where are you getting this whole lawsuit hypothesis from?Wrong answer.
The reason is that GM is a much bigger company, i.e. a much bigger target for lawsuits, so GM has to keep L1 charging very simple and goof-proof. Remember, when it comes to electrical connections, there are a lot of idiots out there, many of whom can end up on a jury.
By contrast, GM's L2 charger must be installed by someone who knows what they're doing, typically a qualified electrician, or if it's installed by the homeowner, you're supposed to get the permit and have it inspected. Either way, the risk of a lawsuit is much lower.
