1 - 10 of 10 Posts
2016 Volt. When we first drive it after it is sitting for a while in the driveway it makes a scraping noise like it is dragging a stick for about a quarter mile or less, then it stops making that noise. If you drive it later that same day you don’t hear it again but you will again just for a short time when first driven later again after the car has sat at least overnight or not driven for a few days. Any ideas? Thanks
Have you gotten under the car? This happened to me but it was metallic. I ran over a large concrete drill bit and it speared one of the pans under the car and stuck there like a dart in a dart board.
Brakes?
Rust on the rotors maybe? Especially if you hear the noise when applying the brakes.
Have a friend walk alongside the car as you slowly drive. Maybe they can pinpoint the noise location.
Thanks. I suspect brakes too since they are not used very much at all with regen but will have one of us alongside to hear exactly where it is coming from.
Is this a continuous noise or just a brief sound at about 20 KPH (12 MPH)? The latter would be the GM ABS system self check. The former???
A continuous noise that lasts about a minute and then stops which is why I’m beginning to think it probably frozen or rust on the rotors. It goes away at that point and doesn’t come back again until the car sits for a while undriven.
rust on the rotors.
It would be visible on the rotors if it was going to make sounds. Do a quick visual before the next time you drive it. You can also pop it into neutral and apply the brakes to make sure the friction brakes are used instead of regen to check the noise during the first minute or two.
-Charlie
  • Like
Reactions: obermd
Discussion Starter · #10 ·
-Charlie
Thanks
1 - 10 of 10 Posts
