I have this issue on my 2016 Volt. Car was crashed when I bought it, I replaced right headlight (part was used but OEM)
• Right high beam is projected to low despite that low beams are adjusted.
• The lower screw changes height of the both beams (high and low beams) at the same time. So if I shift high beam higher up lower beam goes up too.
• Upper screw does nothing (not only for the right headlight but this screw on the left headlight does also noting)
So is any chance I can adjust it?
