1 - 13 of 13 Posts
Its the button for the ambient lighting kit, which was an option for the car. If you press that button, it should change the color of the lights in the footwells and in the front cup holders.
i love that in my premier. miss it in my LT
Thanks for the info. Was this installed at the factory or was it a dealership add-on? Also do the second generation vault have the LED light strip in the door panel like my ELR? I’m purchasing this car site unseen.
I recall the option was a dealer-installed item. (I installed mine so I would be sure it wouldn't be jacked up.)
It was a more-complicated-than normal install. It mainly involved removing trim panels and running the wire harness. However, the procedure requires removing terminals from a harness plug (at the switch circled in the original post) and then drilling holes in the cup holder for the LEDs.
· Administrator
moved to Use, Care, Maintenance...
1 - 13 of 13 Posts
