1 - 14 of 14 Posts
Short answer: No
Technically it is possessible, but it would be prohibitively expensive, assuming the dealer is even willing to assume the liability for installing it.
Here is a rough cost estimate based on retail parts costs and technical schematics:
Front Collision Radar module: $455
Slave modules, radar, side mounted ($250x2) $500
Mounting Bracket for radar module: $124
Assorted mounting screws : $3
Wiring harness A: $235
Wiring harness B: $950
Fuse block wiring: $30
Other neccesary bits and bobs $90
Estimated Labor
15 Hours install (the dashboard must be removed)
2 Hours reprogramming
1 Hour testing
Estimated cost:
Labor ([email protected]$110/hr) $1980
Parts cost : $2387
Total: $4367
Note: I did not include the cost of replacing the steering wheel buttons with properly labeled replacements because the existing buttons will work fine after being reprogrammed.
This is just a "back of the napkin" estimate, but it would seem easier to find a car already equipped from the factory. Honestly, for the price, every single ELR should have come standard with radar cruise. 10 years ago I had a Jaguar that had radar cruise, and it had a lower MSRP than the ELR, even after considering inflation.
Discussion Starter #7
Thanks for the work on the rough cost. It does have the front collision option but might be different.
Like many things would be best to just get a different car if I really wanted it. Just wanted to ask what people's experiences were with that. I know some things can be installed by the dealer like if someone wanted a car but wanted one other option they could install it for the sale.
Manual says FCA with ACC operates differently than without. I'm thinking they are different hardware and code.
I doubt that adding ACC would be attempted by a dealer even if there is a factory procedure.
Premium Member
I think cars.com had a 2014 MY ELR with ACC listed at under $40K. I believe you're looking for an "R" in the fifth spot on the VIN (at least for the 2014 MY and I'd guess the 2016 MY as well).
Now, for MY 2016, the 5th spot on the vin, is either an "L", for the standard model,,, or an "M", for the performance package.
If the 2014 has an S in the fifth spot,,what model is that?
An 'S' has all three major options: Luxury Package, Adaptive Cruise Control, and Kona seats. The only other factory option is the paint color. The silver, dark grey, and black paint are all no-cost options. The red tintcoat was a $995 option.
--Chris
1 - 14 of 14 Posts
