Yesterday I had my car valet parked. After 6 or so hrs I returned and was told the car would not start. I thought the parking attendant did not know how to use the car. I found the car completely dead. No horn, lights, nothing. The outside running lights on the front of the car were on, but very dim. I Googled this and saw that the 12V battery needed to be jumped. After doing this the car was fine except for the orange engine light. OnStar read me some error codes being thrown and after speaking to the dealer, I was told the car could reset itself - which it has not.
Error Codes:
The code(s) and explanation(s) associated with this issue is/are:
P0AC4 The electric propulsion system is not performing as expected. Please service within 7 days. There is another trouble code in the HCP, which may or may not be active at this time. If no there code is found, service within 7 days.
P1F64 The Engine and Transmission System is not performing as expected. An issue has been detected in the Hybrid Powertrain System that monitors and controls the use of power between the combustion engine and the electric drive system.
P25C9 The Engine and Transmission System is not performing as expected. An issue has been detected in the Fuel Management System used to maintain, control and monitor fuel consumption. If the check engine light is flashing, a misfire condition has been detected. A misfire increases vehicle emissions and could damage the emission control system on the vehicle. Please reduce vehicle speed, avoid hard accelerations, avoid steep uphill grades, and reduce any cargo loads such as a trailer.
Based on the results, you should service your Chevrolet within 7 days.
I've made an appointment to bring it in, but the dealer told me the codes could clear on their own by then.
How is the 12 volt battery charged? Does it come from daily charging or from the main battery? This took place after a 2hr drive using the engine for most of the trip. I had plenty of lithium battery left and gas.
The dealer feels it is fine to drive as long as the engine light is not flashing. It's just on. All recalls have been done.
I'm thinking the Valet left the car on - but would that cause this? What do you guys think? What could drain the 12V?
Error Codes:
