1 - 4 of 4 Posts
I'm new to Volt world, and wanted to see if this is normal...
About a month ago I purchased a '15 Volt Premium. When charging overnight, in an unheated insulated garage (avg temps around 30-50*F), for about 10 minutes I hear a clicking noise from the rear passenger side. It sounds like a relay switch. No discernible pattern.
Is this normal while charging, or should I have it checked out?
Thank you for your knowledge and sharing.
That's the fuel tank pressurization system. It's normal. Has nothing to do with charging, a coincidence.
The Volt takes 3 days to sleep. It'll mutter and grumble to itself quite a bit.
1 - 4 of 4 Posts
