1 - 7 of 7 Posts
Hi Forum,
I have a 2015.
I normally get 39-42 miles per charge.
The past few days, the car says it is fully charged but only reads 29-30 miles?
I live in So Cal?
Is this normal?
Due to climate change or the rain?
Any input is appreciated.
Thanks!!!!
We call that the 'guess-o-meter' since it is estimating what your future range will be.
Affected by: terrain, climate (temperature), driving style, cabin HVAC, accessories, tire pressure and any other variable that affects vehicle efficiency.
Today's high in Lomita, CA is 55F. What was the average temperature for the previous two weeks? Temp and tire pressure seem to be the biggest culprits for lower AER (All Electric Range).
It’s normal for the distance you can drive on a full tank of fuel to go up and down throughout the year as the weather gets warmer and colder and impacts your mileage. For most of us, the Volt is the first car we’ve driven whose main fuel tank (the battery) holds only the equivalent of one gallon’s worth of driving distance. We’re not accustomed to seeing a "start of the morning" estimate of how far we’re likely to drive before the tank is empty, so when that estimate heads down to the bottom of the annual cycle as winter arrives, we’re flabbergasted. Does the mileage really drop that far? Yes, it can (especially in cold climates). Dealing with it "one gallon's worth of distance" at a time magnifies the astonishment.
We tend to forget, too, the end of daylight savings time in the fall triggers changes in the ambient temperatures and daylight we experience as we commute to work and back, causing increases in the portion of battery power used for lights, wipers, window defrosting, and cabin heat, and decreases in the portion available for propulsion.
The good news is Google may make a better meter as they already know where you live and where you are going as well as how fast you like to drive :)
I THINK I AM KIDDING-- but will take more information than the volt knows to get a good number.
· Premium Member
You might also want to check the OnStar app to ensure you've charged to 100%. Also, have you possibly gotten new tires? Honestly that does seem to be an extreme drop in estimated range. Any trips to go skiing?
It has been raining, which will cost you about 15% of your typical efficiency. Also, if you are running climate control or the defroster, that energy will start to affect your range estimates.
The Volt's range estimator is just an estimator, so any number of factors will make the estimate increase or decrease.
I also have a 2015 volt, I bought brand new
the condition you are experiencing is perfectly normal,and it is affected by several factors.
1. you"re volt learn"s your driving habit's,and learn"s your driving habit"s and memorises them
2. the weather also affects the battery,and when you shut your car off at work,you might lose a few ev miles when you start for home because of the weather.
3. my 2015 volt still guesses about everything including the driving range while on ice,even though I just filled the gas tank.
just enjoy your ride,and congradulation's on driving an awesome car!!!
1 - 7 of 7 Posts
