Hi,
I am the owner of a recently purchased 2015 Chevy Volt with relatively low mileage. I am really excited about being a first-time electric car owner and and have started delving into the car's features. I've read through much of the manual and talked to another Chevy Volt owner and would appreciate a few clarifications.
1) How important is the radiator screen? The other owner says that it is very highly recommended to get one. I mostly plan to drive local roads and some highway, and don't really plan to go off road or on gravel roads. How likely is it that I would run into an issue with damaging the radiator? Seems that the screen itself is really cheap, so it's not a matter of cost. However, another forum states that radiator damage is "really rare" so I am just wondering from a practical standpoint whether this is worth it?
2) Thermal sensor - does the 2015 have the same thermal sensor attached to the battery as the other earlier version 1 Chevy Volt models? I heard that this is the "faultiest" component associated with the battery. If that goes, the whole battery needs to be replaced. I realize I've got a bit of time before I would need to worry about that due to the warranty, but I am curious if that is something I need to keep in the back of my mind. Is a 2015 thermal sensor on the battery the same type of thermal sensor as on the the 2012?
3) Proximity sensor - how do I turn the damned thing off?! It just keeps beeping and beeping when I pull into my garage or park at a public parking area next t a pylon, and I find it extremely annoying. I know in principle, it is supposed to help, but in my case, it just stresses me out. Is there a way to turn it off or at least silence/quiet the beeping?
4) Efficiency - tips and tricks for increasing driving efficiency. Right now, I most drive on 'D' - very gently break, mostly flat city roads at 30-40 mph and somehow I still can't get better than 79% efficiency. What can I do to improve this? I usually have the climate settings on 'fan only' or totally turned off with only the occasional warming of the seat. And again, my climate efficiency shows that it is in the 60s% even when I am not using ANY climate control features, so EVERYTHING is off including the seat heat. Someone suggested, perhaps the defogger is on auto, and that eats up some of teh efficiency, but I do not believe that is the case because I usually have to turn the defogger manually. How do I check if the auto defogger is on?
Answers to any or all questions will be much appreciated!
