Spark EVs have a ~105 kW electric motor. Cruising at 60MPH, the motor is likely drawing about 10-15 kW from the battery continuously. The battery is designed to deliver 100kW. I would think that charging at 1 kW vs 3.3kW vs 6.6kW is pretty trivial, especially considering the battery has active liquid cooling. It would be heat that causes degradation. I assume the liquid cooling also functions while charging. I would not worry about 240V charging. Now if you charged it every day with DCFC at (unsure of the rate, speculating 80% charge in 20 minutes) 50kW, that might shorten the battery life...
