2015 rear camera fuse keeps blowing? Anyone know where common shorts are?
25890 Views 36 Replies 15 Participants Last post by  Viorel
Hey every one, I am out of wrranty, and my rear view cam stopped working.
I read here a guy with a lease had the smae problem, it was the fuse, and like him, I chagned the fuse, and if blew again.
Is this a common problem???
Do you guys know where the common shorts are??? I do not want to go a wild goose chase...
thanks in advance !
21 - 37 of 37 Posts
Did a ground come lose somewhere? That can cause current to flow weird to find the ground.
Ya, this sounds a lot like a bad ground. Have you checked your battery cables? Also, how old is your 12V battery? A bad battery has been known to cause a myriad of problems.
Car is less than 2 years old...
Car is used 5-6 times a week. I dont think the 12v should be bad as of yet.
I tried to remove the driver visor. Once it was free from te headliner, there was no plug at the end... how long is this harness??? anyone know wher to fin detail drawings of this?
I would suspect it is the visor, I move it everyday, 3- 4 times a day.. ( I drive 85 miles each day)
what is also weird are that my rear cargo light and the dome light still work too. AM i reading this right , that they are all on the same circuit...
anyone know wher G202 ground is located?
The sun visor lights are both connected to the same F7DR fuse.
I wouldn't completely rule out the battery. There were a few instances of bad batteries that only lasted a year or so.
Try putting the car in Reverse, and moving the visor back and forth repeatedly. If the camera cuts out while you are doing that, then you may have found the issue.
I'ii check it.... is it the traditional 12.3v + good batt ????
In the passenger compartment, behind the right side of the instrument panel, above the glove box, on the instrument panel support
For now, to help you out, put a circuit breaker fuse in. I had a mustang that liked to short out the power to the AC. When it blew the AC compressor wouldn't work. I changed every part I could find, traced wires, couldn't figure it out. It wouldn't immediately blow the fuse either, sometimes weeks would go by. So I picked up a circuit breaker fuse, it would trip, the car would blow hot air and a few seconds later it would reconnect and I would have AC again. Get one rated for the same 7.5amps you have though so you don't cause a fire.
They have manual ones: https://powerwerx.com/resettable-atc-blade-circuit-breakers?gclid=CMezyLL_79MCFU5ffgodnuQEhg
and the one I had was automatic: https://www.delcity.net/store/Maxi-...p_kw=&mp_mt=&gclid=CM3xqsb_79MCFYJYfgod-t4IuA
Your local auto supply store should have them - I just googled and pasted the first links I found... IIRC, I got mine at Discount Auto Parts which is now AutoZone.
So everyone knows, I found the problem. it was the visor. Thank you for the reply of one of the members that said that was the problem for them.
Had to remove the visor and the ! pillar trip to unplug in. Now no more uses blowing
I have the same issue with the F7 fuse repeatedly blowing after replacement
I got as far as removing the driver's side visor (until it was dangling by the wiring)
how did you get the plug exposed so you could disconnect/unplug it cleanly ? - "removed pillar trim" ? is there a procedure/pics on this?
(this presumably resolves the issue by removing a short circuit in the visor wiring ?)
I called AutoZone and Pepboys about the circuit breaker fuse option while I track the short down - they did not have them, but Napa had this part# BK_7823151 Circuit Breaker, Low Profile, Type III, CB227, 7.5 Amp
thanks for any info/tips!
Will follow up with resolution!
Hopefully another member will post the proper procedure so you can access the plug. Until then, be careful. I believe there is a side curtain air bag inside the A pillar, so I would not go randomly poking around in there. I think I would just cut the wire as short as possible and hope that removes the trouble spot.
Update I used the instructions/diagram in the tweeter upgrade thread
to take off the drivers side A-pillar cover, but did not find the sun visor wiring underneath - just the tweeter and the tiedown for the curtain airbag
I'm guessing the sun visor wiring goes to the roof center onstar/dome light console??
thanks
Basically looking for how to "Disconnect the electrical connector." for the sun shade / visor
Text Line art Line Diagram Font
Anyone know ?
thanks!
I was able to pull the overhead console off, but its not obvious if the sun visor / shade circuit is tied into the wiring in this area.
Vehicle Engine Auto part Electronics Car
@cueballsi - where is the visor circuit plug / connector located?
thanks
Ok, decided to just cut the driver's side sun visor wire to eliminate the short - FIXED:
back up camera,
daytime passenger running light
back up lights,
map lights
Technology Auto part Action figure Fictional character Toy
I just won't have a visor light - no big deal considering what I gained back
thanks!
back up camera,
back up lights,
map lights
thanks!
You are awesome. Traced this issue for weeks! Finally found this post and got some confidence to cut those wires. Fixed all my issues.
Thanks!
Yes, known issue, I had that issue in 2019 and I ended up cutting the wires too. Never had an issue since.
21 - 37 of 37 Posts
