So drove volt home. Started in electric mode, but it switched to gas before getting home. Didn't charge right away. So after about 3 days went to pull into the garage to put on charger, but car would not start. Steering wheel was difficult to turn, but assumed because car would not start. Pushed car into garage.
Got yellow light on car when trying to charge that eventually went out. Code was PE100. And some other things showing up like low tire pressure. Checked 12v battery and it was low in voltage. Removed and had tested. Was original, and test said bad, so replaced.
Most things went off like low tire pressure, but car still will not start or charge. Still have the PE100 code. I don't think it ever got set to service mode, but went through procedures to get it out just in case.
Does the error codes or something need to be cleared before I can charge and start? Any other thoughts? Would appreciate any input.
