1 - 18 of 18 Posts
Hi all
I'm new here and this is my first post.
I bought a used 2014 Volt in June and imported it to Iceland, Europe. When I got it the EV range was around 40 miles. In the beginning of October the range started to gradually degrade and is now 26 miles. Has anyone experienced something like this? Can I somehow check the battery cell status myself? Since it's imported from the US I'm not sure the local dealer is willing to help. The car is kept inside overnight so it's not because of the colder weather.
· Administrator
It goes down when it's cold. My worst day a few weeks back was about 26 miles when I'm usually in the mid to night 30s. It also goes down if you go too fast or drive it like a jackrabbit. You can't do much about the cold, but you can drive slower and avoid using the heat too much. Me, I just set it on comfort and drive, not worrying about the range drop. It happens every winter, fixes itself every spring.
I am able to eek out about 5 miles more of range on cold days when I put it into hold mode for my highway trip into town. My commute is 65 miles round trip, so I will always hit the Dino juice. By using hold, I get heat from the ICE and when I hit the city, switch to normal. The car is much more efficient in stop and go driving than continuous highway
Yes, drop in range is normal due to the colder weather. 20-26 miles is what I am seeing in my 2013 already. Below about 14 celcius is when it starts to really happen. Between 3 celcius and 10 celcius is the worst for range.
Hi all
What you're seeing would be normal in your recent weather (basing on Reykjavik) for short journeys.
Our estimate is currently 32 miles.
Unless you're driving inside as well, the ambient temp is going to be a part of it. Anything below 16C will use more energy than above.
The car may start at say, 20C, but driving outside it will cool off to ambient. And is it parked in a heated garage at work? If not, the drive home will use more energy.
See post below:
14 is just under the battery heat threshold, so no surprise.
3-10 will be using a lot of battery heat (plus probably some cabin heat?), so again, no surprise
And on top of that, did you top up the tires?
I already gave mine a good top up since summer and they're a little low on those single digit mornings. Need to do another.
You got your car at peak range season, so unfortunately, the largest shock is yet to come.
I bought mine in late winter/early spring, so I knew what a healthy middle point was, then experienced the high, and the low.
A fully charged Volt battery holds a fairly consistent amount of power each time you recharge it, represented by 10 green bars on the display screen.
How far you personally can drive on those 10 bars of power depends in many ways on the same factors that determine how far you can drive on a full tank of gas, i.e., your driving habits, the weather and terrain, and the condition of the car (e.g., new/old tires, etc.).
Electric cars, however, also draw power from the battery for the accessories (heat and air conditioning may use significant amounts), leaving less as fuel for the electric traction motor. Turning up the heat or a/c may reduce the ev driving range.
Bad weather can require the car to use more power to move the same distance (takes more power to move through falling rain and cold, dense air and to splash through puddles on wet pavement, etc.), and such conditions often are coupled with increasing use of heat and window defrosting. Most Volt drivers experience annual range cycles, increasing during warmer seasons, decreasing in the colder seasons.
The full charge ev range display is the computer’s estimate, based on the data it has recorded of your past driving achievements, of how far those 10 bars of power will enable you to drive if you drive as you normally do. If the weather or your driving habits change, or if someone else drives the car, the car’s electric mileage for that particular full charge may improve or deteriorate.
· Premium Member
Also low tire pressure or especially new tires will take a bite out of range. But yes, if it's very cold you will notice.
We have seen either very few or zero problems with the battery. Relates systems yes, but not the battery cells per se.
Discussion Starter · #9 ·
Thanks for all you replies, I really like this forum. My concern is that I charge the car inside in ~68°F. When it's fully charged, 10 bars the range shows around 26 miles.
I understand it will degrade based on temperature and weather as well.
· Administrator
How you drive also affects the ESTIMATED range that is shown. The more aggressive you are, the lower the range estimate will be.
Someone correct me if I'm wrong, but as I understand it, the displayed range is based on past performance and is an estimate. If you drove up a HUGE hill at 10°C with the heat on, rear defroster on, and the heated seats on your range will be significantly less than what it may have displayed when you set out with a full charge. The next time you get a full charge the displayed range may be significantly less because past performance indicated that estimate was WAY off. It doesn't mean that the battery is going bad necessarily, just that your usage is burning the energy at a higher rate than anticipated.
The temperature when you’re driving the car affects the full charge estimated range far more than the temperature surrounding the car when you are charging it. A full charge range of 26 miles means the computer estimates you’ll go ~2.6 miles for each green bar of power you use. See if you can drive more efficiently, use less heat, etc. If better driving habits can increase that to ~3+ miles per green bar, the full charge estimate will also increase. Press the leaf button and observe the usage display in the center stack. How far can you drive on 1 kWh of power used? See if you can get it up to 3 miles/kWh or more... Increasing ranges, of course, usually return in the spring...
There’s nothing really mysterious about range estimates... multiply the amount of available fuel by some sort of mileage figure to get the range. But let’s also acknowledge that there is a difference between the "full charge" range estimate and the "on the fly" estimate you see once you unplug and start to drive down the road.
The full charge range estimate is based on historical data regarding your driving. The calculation is influenced more by recent driving history than by past events. If you reach home after driving for miles up steep hills with the heat blasting away, the impact that power demand had on the electric mileage during the final leg of your drive may indeed negatively influence the next day’s full charge range estimate. I suspect the overnight ambient temperature in the garage where the car is being recharged plays little part in the full charge range estimate. The computer analyzes the data, then uses an algorithm to calculate an average electric mileage figure appropriate for use for the next full charge. The full charge range estimate is nothing more than this number multiplied by the amount of available power in the fully charged battery.
You don’t have to drive far enough to deplete your battery to get your full charge estimate to increase, you can do it by getting great mileage when making those short trips. Better mileage multiplied by available power in the full charge = higher full charge ev range estimates.
Once you start driving, the range estimate is soon influenced by the driving conditions you are experiencing. The computer’s algorithm creates an "on the fly" estimate of the battery soc to determine the remaining amount of power, adjusts the full charge mileage estimate to reflect current conditions (speed, terrain, weather conditions, etc.), and then calculates the estimated remaining range. When the range goes up while driving downhill, for example, many people think downhill regen is "adding miles to the range," but it’s really not... most of that increase is because the car thinks you’re going to keep driving downhill, and downhill mileage is better than level terrain mileage, so the distance that can be driven using the available power increases. Once you hit level terrain again, the estimated range will quickly decrease as it adjusts itself back to level terrain mileage.
· Super Moderator
2012 Std w Nav
It does, though, seem to use a substantial window for the milage estimate. You won't get a lot of influence from a two-mile downslope because that'll probably be counteracted someplace in the next 50 mile or so with a corresponding upslope to balance it out.
Discussion Starter · #14 ·
Thanks all for very good replies. After I learned the range is an estimate based on previous use it all clears up. It's colder now. My wife uses the heater a lot and the car is kept outside during the day. In addition I have studded tires and only 38 PSI (read that some people go up to 50 PSI) :)
· Super Moderator
2012 Std w Nav
38PSI is entirely reasonable for winter tires. High PSIs are risky unless you've got a LOT of grip to spare.
I thought Iceland was supposed to be warm and green whereas Greenland was really cold and icy (a huge practical joke to the world - not too different from the recent US election).
· Super Moderator
2012 Std w Nav
It is, relatively. Smallish place, surrounded by a warm-water current. It's just at about the same latitude as Denali, which is about half way to the North Pole from what you and I consider normal.
Discussion Starter · #18 ·
LOL, it's all warm and green during the summer :) Never very hot but never very cold either. Today it's around 39-48h °F
1 - 18 of 18 Posts
