1 - 9 of 9 Posts
Our displays were doing a few odd things the last couple of weeks (first time ever). The details seemed to be unrelated to each other. At first I suspected the 12V battery was going but that tested out fine (very good health in fact).
There were 6 software updates applied today, which were done through the USB port. This is something I've not seen done before. My service receipt says:
HEATING / COOLING TECH(S):283 INTERNAL
CUSOTMER STATES COULD NOT ADJUST CLIMATE CONTROL
ADVISED
ENGINE MAJOR TECH(S):283 INTERNAL
CUSTOMER VEHICLE WAS IN MOUNTAIN MODE AND SWITCH OVER TO
NORMAL MODE STILL SHOWED FUEL GAGE NOT ELECTRIC
PROGRAMMING
BODY ELECTRICAL TECH(S):283 INTERNAL
INT SCREEN FREEZES----WITH RADIO TOO
PROGRAMMING
BODY ELECT CONCERN TECH(S):283 WARRANTY
CUSTOMER STATES TOUCHED HOME BUTTON ON DISPLAY AND DID NOT
DO ANYTHING EXCEPT BEEP THREE TIMES
15-NA-081: Radio Locks Up and/or Resets, Bluetooth Pairing,
IPhone Loses Pairing, Bluetooth Connection And Audio
Concerns, Street Names Flickering, TBT Routing Screen
Displayed After Download is Finished, XM Weather Alerts
Cannot Be Selected Off, Voice Recognition and Navigation
Updates, Various Rear Vision Camera Concerns, Podcast Will
Not Play, Cannot Edit Device List - (May 25, 2016
REPROGRAMMED RADIO
Some of the items in 15-NA-081 were not complaints we had, but I suspect they are fixes for complaints others have had. Just a heads-up for people like me who may not have had any software updates in a while. We know that our dealers/GM don't inform us when updates are available unless we're there with complaints.
Could you supply the version #s listed on your radio?
I asked in the other thread (http://gm-volt.com/forum/showthread.php?241377-Various-Radio-Bluetooth-Voice-and-Navigation-Issues-2014-15-Volt-Bulletin-15-NA-081)
But never got a response.
Wondering if I already have the latest update or not as mine was updated shortly before the bulletin was released.
Sorry about that.
Correlation of the files shown in your display is difficult as at the TIS2WEB SPS-end the numbering systems are different making the ability to display calibration numbers in the car essentially useless from a service standpoint
(and the reason why you won't see a Volt tech using the center stack display to verify files)
But comparing 2 cars should help (given one was more recently updated) ;)
WOT
Discussion Starter #4
Where would I find this? Maybe if you listed yours I could find a comparable number on my service receipt.
What I can tell you is that my '14 was built in late '13 if that helps any.
In the car radio menus buried in there somewhere is a listing of a whole bunch of software packages and version #s
I don't know what each means, but perhaps comparing our lists might make something stand out
I snapped these photos after reading about the bulletin initially:
Discussion Starter #6
View attachment 111793 View attachment 111801 View attachment 111809
I can go out and look at what my update list shows in a bit. I suspect we have had all of the same ones, and we got them OTA. This could be why my car had never acted up prior to last week. Just for reference, I don't use nav, bluetooth or anything iPhone related, so I would not have seen any issues with those things.
Stand by......
Discussion Starter #7 (Edited)
This is my list, which is found under config>radio settings
84009432 version E0.11.1F.40
77777777 version E0.00.41.55
84019249 version C1.11.1F.40
84006375 version C1.11.1F.40
84019246 version C1.11.23.A0
23164544 version 00.01.25.13
84019247 version 30.67.09.04
I don't have as many entries as you do. Just a guess but I think you may be looking for:
AFAIK, I haven't had any recent updates, no issues to report either. MY2014, build sticker 12/13.
1st screen:
23207170 version E0.0E.15.02
22768311 version E0.0E.15.02
22768303 version E0.0E.15.02
22768304 version E0.0E.15.02
22768305 version E0.0E.15.02
22768306 version E0.0E.15.02
2nd screen:
22768307 version E0.0E.15.02
22768308 version E0.0E.15.02
22768309 version E0.0E.15.02
22768310 version E0.0E.15.02
22950148 version C4.0E.15.06
3rd screen:
23208328 version C4.0E.15.06
50000001 version C4.0E.1E.40
23111189 version 10.0E.0C.31
23164647 version 30.5F.06.20
More like Canehdian
Interesting how different they are.
I thought the first number would be constant (refer to a package for x item) and the version would change
But it seems both numbers change, or perhaps Dave has an entirely different radio version (hardware revision) than ours, needing a completely different set of packages? My build was Jan 2014, so if edk hasn't had any updates, those in common with mine are probably unchanged from the factory.
Either way, I don't think we'll get anything useful out of this comparison without knowing the naming structure :(
Here are mine typed out for future ref:
23206558 E0.0E.15.02
22768311 E0.0E.15.02
22768303 E0.0E.15.02
22768304 E0.0E.15.02
22768305 E0.0E.15.02
22768306 E0.0E.15.02
22768307 E0.0E.15.02
22768308 E0.0E.15.02
22768309 E0.0E.15.02
22768310 E0.0E.15.02
77777777 E0.00.41.55
22950148 C1.0E.15.06
23206819 C1.0E.15.06
50000001 C1.0E.1E.40
23164544 00.01.25.13
23164647 30.5F.06.20
1 - 9 of 9 Posts
