1 - 7 of 7 Posts
I have a 2014 Volt and just recently got this message. The Volt seems to be running fine, it just doesn't charge when I plug it into the 240 volt charger or a regular wall outlet. We have an appointment for Monday. Hopefully its just the coolant pump like I read on some other posts. When I take the Volt out I put it in Mountain mode so it does charge the battery. I haven't seen any leaks on my garage floor, so I don't think coolant is leaking. I've had the Volt for 6 years now and have been very happy with it. The only annoying problems I've had are two incidences flat tires. The fix a flat canister thing did not work, so I had to call a tow truck both times. Replaced the factory tires with something else and haven't had any more problems. I get my Volt serviced at Larry Green Chevrolet in Cottonwood, Arizona. Anybody else?
Do you recall what the lights on the top of the dash did and also the lights on the EVSE?
There is a pinned thread at the top of this forum. I would assume you are probably falling victim to the same thing as a lot of others (including myself). Sensor in reservoir most likely needs replaced and even with replacing it you need to have 2 modules reprogrammed to clear codes (will keep coming back even if you clear them with a generic scan tool). Is a fairly simple DIY, you just need to buy the sensor (or an override device), a programmer, and a subscription to ACDelco's service program. All will cost less than the dealer will charge, and the subscription is good for 2 years, so you can troubleshoot future problems.
Discussion Starter #5
Wow! DIY? The last time I think I worked on a car was changing my oil on my 1976 Ford Granada! But thanks for the info. at least I now know more than I did yesterday about the car, so less likely I'll be taken advantage of. Thanks again!
One stayed solid yellow and the other one didn't light up at all. What is the EVSE?
EVSE=electric vehicle supply equipment
The EVSE is the "charger". It's the unit that plugs into the wall and plugs into the side of the car.
Check your battery coolant too, I recently had this error as well. Coolant was to about 50% full, dealer reprogrammed the ECU and topped it off free o charge.
1 - 7 of 7 Posts
