My volt is not taking a charge with either 220 or 110. The yellow light comes on and goes out. The dash says not able to charge. I replaced the charge port, but same problem.
After scanning with my obd2link I got the following codes.
P1EE6
I cleared the codes and scanned again and got
C0242 pending.
I had the P1EE6 code on my 2013 last February (2022). Took it to dealer who checked it. Receipt says;" Verify receptacle on vehicle OK Checked connections and internal fuzes after system check and reset check charger working OK at this time". "Could not duplicate refer to tsb 12-08-45-001a Device power ciruit voltage below threshold: The first thing to do is to check for low A/C supply voltage. If the circuit is not dedicated with good wall plug, charging should be done at reduced rate" Total labor and parts $185
Got it home and it worked fine. So they blamed my charger/electrical system which has worked fine for the last 10 years.
Maybe there was some power problem that freaked the volt out, bottom line Chevy reset it, fixed problem.
Until today! I am getting the "not able to charge message" again, yellow light comes on goes out.. stumbled on this thread looking for a quick fix without having to return to dealer.
