Hi everyone, one of my Volts has an issue. It has the service brake assist message on the dash with fault code C1125. I replaced the wheel bearing and the wheel sensor. I gave up and brought it into a GM dealership. They said that the brake pressure modulator valve needed to be replaced. They refuse to cover it under warranty even though it clearly states in the owner's manual the brake modulator assembly is covered under the Voltec Warranty.
The GM dealership stated that because my car doesn't have RPO code JE0(Mine has J60) that it is not covered.
I've contacted GM directly and they only offered to cover 40% of the repair.
How do I get it covered under the Voltec warranty? I've tried 3 different dealerships in the area.
