1 - 17 of 17 Posts
2014 Chevrolet Volt premium
I looked through the settings and did a few searches of this forum but haven't found relevant info. When I get out of my 2014 Volt while it is fully powered on (in Park) and close the driver's door, the horn honks and a message displays on the dash saying "no remote detected." Is it possible to disable this?
I have been doing deliveries at night and have to leave the door open to avoid the honk. I don't want to shut down the car for a quick dropoff 20' away (plus it keeps my cameras recording.)
· Administrator
moved to Use, Care...
Leaving the driver’s door open, of course, gets that ding ding ding thing going... That triple honk when you shut the door is a safety feature to remind you you’ve removed the fob from the car and the car is still turned on and running. You could leave your fob in the cubby by the shift lever while you get out to drop off deliveries (if you are not concerned with getting your car hijacked), or I suppose if you still have two fobs, you could leave one in the car.
Someone posted that if before exiting, the driver rolls down the driver's window and once the door is closed from outside, reach back through the window with the key fob and this will defeat the triple beep. I tried, didn't work.
Seems to me that hint may work, if you pay attention to the sequencing of the actions. The triple honk is to alert you you forgot to turn off your Volt before getting out and taking the fob with you (and thus the car is still driveable, or it may sit there running until the battery is depleted and the engine starts up to keep the charge maintained, and fills the garage with carbon monoxide).
The alarm doesn’t sound as the driver exits the car, but when the driver closes the door with no fob inside the car. If the alarm trigger is the closing of the door, perhaps you could get around it by rolling down the driver’s window before exiting, then get out and stick your arm though the open window to hold the fob in your hand inside the car as you then close the door... fob is still inside the car when the door is shut, so no alarm... and then bring you hand outside the car and stick the fob back in your pocket or wherever...
After going through that hurdle of steps I'd just as well hear the damn honk ... I just lean the door without actually closing it fully but as mentioned you do get the "ding ding" but that's the lesser of the 2 noises for me.
OpenEVSE x2, 2013 Volt base + added tow hitch, K&N filters, 3d printed mods; 2023 Model Y
There was a thread awhile back about a horn temporary disable switch install. I looked at it, decided it wasn't worth it for me to do, but might be for you.
Agreed that triple honk is my number one annoyance with the car now. If I had known that was going to be a permanent feature of the car I would have never let them do the recall that made it that way.
2014 Volt base
... I just lean the door without actually closing it fully .... you do get the "ding ding" ...
And I'm outside the car, not inside, so the ding-ding is less annoying to me. And the purpose was so that I could walk away from the car, for whatever reason, so I'm getting further from the ding-ding source.
Now, if Mrs. is sitting in the car, I have empathy and shut down and take the key so she won't have reason to provide a third 'noise' for me to hear when I return....
· Super Moderator
2012 Std w Nav
Because it PARTLY determines whether to honk by whether the driver's seat is occupied. Passengers can get in and out all day with the car on, and it's fine. The driver can open and close that door all day too, as long as they're seated.
Discussion Starter · #10 ·
Thanks! I didn't know where to put it but this makes sense.
... That triple honk when you shut the door is a safety feature...
It's a great safety feature, however, I would like the option to customize it.
Wouldn't leaving a second fob in the car cause a host of additional issues?
I suspected that your sequence was wrong. I confirmed that this does work if you reach in before closing the door.
Yup, I confirmed that works after reading the prior reply. This gives me an option that I can use at times.
I deliver at night when people say do not knock or ring the bell due to dogs and/or others sleeping. That gives me more reason not to "honk" when I arrive. I've been leaving the door open and try to park so that the driver's side is to the curb, but sometimes I have to park with the open door in the street. I'm more concerned about it getting hit by a passing car than someone jumping in. I do lock up when I feel it's best to secure it ;)
I just tried it and you are mistaken. I remained seated, opened and closed the door, no honk. Again I opened the door, tossed out the fob, closed the door and heard the honk.
· Administrator
Maybe just turning the car off is easier.
Try this. Start car normally. Toss the fob out the window into garage, rosebushes, girlfriend's brassiere, yard etc. as applicable, when you depart home. Retrieve and inspect carefully when you return. Report back here. It won't solve the 3-beep problem, but we will enjoy hearing about it.
Be careful not to accidentally turn off your car while on appointed rounds. :D :D;)
· Administrator
This has already happened to some. In one case the wife drove to work with her husband, she left the drivers seat, he got in and drove away not realizing she still had the key fob. Like you say, Cloudnine, just don't turn off the car. Unless you are home and in the house with the extra set of keys. Or are picking up the wife, whichever comes first!
Just a reminder, if you park your Volt and press the blue button to turn it off, and for some reason there is no fob in the car (or the fob battery has lost its magic), a message will appear on the driver’s display saying something like, No Remote Detected, Press Brake to Restart. I can’t remember if the system also sounds a chime to let you know there’s this message on the screen. For the next few minutes you have the chance to restart the car without a fob (perhaps your fob is, for example, in the pocket of the passenger you earlier dropped off at work or school) by pressing the brake and the start button. I don’t know if this chance to restart the car will still be there if you’ve opened and closed the driver’s door before realizing you don’t have the fob with you.
I learned earlier today that in the 2012 Volt I’ve been driving for nearly 11 years, the "fob outside a running car" alarm will sound even if the driver’s seat is occupied. I got in my car and pressed the blue button to start it. I then opened the driver’s window, and held the fob in my hand and stuck my arm out the window and held the fob outside the car as I opened and closed the door with my other hand while sitting in the driver’s seat. The triple honk alarm sounded to let me know the car was running but there was no fob inside the car. Didn’t matter that I was sitting in the driver’s seat.
I then got out of the still running car with the fob in my hand (ding ding ding because the driver’s door was open), reached my arm through the open window to hold the fob within the car, then closed the door. No alarm sounded (because the fob was inside the car). I then drew my arm and fob back out the window, and no alarm sounded when the fob was outside the car.
I don’t know if this is a "one time" alarm, but I suspect it is. That is, the first time the driver’s door is opened and closed when the fob is outside the running car, the alarm will sound, but any further opening and closing of the door with the fob outside the running car will not set off any alarm.
I strongly suspect that the driver’s door is the only door that will trigger this alarm. That is, if the fob is outside the running car when a passenger gets out and shuts the passenger door, there will be no alarm. Thus if you get in the car to drive your wife to work, and your fob is still in the house, but hers is in her purse, the fob in the purse of the passenger allows you to start the car and drive off... then when she gets out to go to work and shuts the door, there’s no alarm to remind you she is taking her fob with her, and now there is no fob remaining in the car, so if you stop somewhere on the way home and turn off the car, you can’t restart it because she has her fob and your fob is at home.
...or just hand her the fob!
1 - 17 of 17 Posts
