Well finally got the hood open on my 2014 Chevy Volt! The polished aluminum grills will lift from the bottom and expose the plastic front end frame. I cut holes in the frame at the level of the hood latch, exposing 2 - 13mm bolts that hold the hood latch to the frame. Lifting hood, the latch came up along with plastic cover over the latch, prying the hold down grommets loose and hood sensor wire as we lifted the hood.It looks like a challenge. The mechanism under the hood is right on top of a radiator/condenser which will likely inhibit reaching it from underneath. Are you sure it is disconnected at that end? Is it definitely still connected to the release handle in the passenger cabin?
Any chance of some pictures?Well finally got the hood open on my 2014 Chevy Volt! The polished aluminum grills will lift from the bottom and expose the plastic front end frame. I cut holes in the frame at the level of the hood latch, exposing 2 - 13mm bolts that hold the hood latch to the frame. Lifting hood, the latch came up along with plastic cover over the latch, prying the hold down grommets loose and hood sensor wire as we lifted the hood.
The ball on the end of the latch cable had lifted out of its Grove on the release mechanism. I applied silicone sealant to negate the possibility that the cable could lift out again?
Upon inspecting the latch mechanism, it appears I could have inserted a stiff wire with a 3 incn bent 90 degree into the lower front passenger side hole in the latch assembly and accomplished the initial release of the hood?
I have it back together now, latch is now covered by the plastic cover and grill price is covering the holes cut in the front plastic. If you need, I can take it off, for pictures? Small tip, don't push the hood release in forcefully. Think that is how I allowed the cable to pop out of its Grove? Cable is now glued into the slot.Any chance of some pictures?
I did get a picture of the of the disassembledI have it back together now, latch is now covered by the plastic cover and grill price is covering the holes cut in the front plastic. If you need, I can take it off, for pictures? Small tip, don't push the hood release in forcefully. Think that is how I allowed the cable to pop out of its Grove? Cable is now glued into the slot.
