1 - 10 of 10 Posts
I'm wondering if anyone has had similar trouble charging:
Several months ago I noticed my 2013 wouldn't charge upon plugging in the J1772 Plug. The vehicle charge light flashed solid yellow for 2-3 seconds. I tried two different cords with the same result, but then I tried again the next day and it worked. It continued working without any trouble since then until earlier this week. I am experiencing the same 2-3 second solid amber light then the charge light remains off until I click the plug button or replace/insert the plug. I have read several posts suggesting that the receptacle may be bad, but I removed/inspected/continuity-tested the receptacle for cracks or damage without any sign of issue. I hear the Charge Controller Module "click" as I plug it in so it seems to be communicating to that point. I've also read something about a charge contactor/relay on the "contactor assembly" that can fail, but I am not sure how to access it. See highlighted.
Any insights would be greatly appreciated.
171396
Check the metal contact points on the charge cord plug and the car’s receptacle. Once, I had a moth head towards the light and kamikaze itself to an untimely death. The bug guts were enough to stop the EVSE from charging. Don’t worry about using a screwdriver to do the cleaning, it shouldn’t kill you.
  • Like
Reactions: sparkrov
2014 Cadillac ELR
You looked at the back of the receptacle after removing it? That's where the cracks happen. Really small cracks.
Have you tried both 120V and 240V charging? Does one work but not the other?
  • Like
Reactions: sparkrov
Mine had a not so small crack in the rear that could only be seen once removed...was definitely the cause of the fault!;)
Discussion Starter #6
The problem is resolved. I replaced the on board charger and everything works. Most difficult part was removing the front bumper. Thanks all!
2014 Cadillac ELR
Good work, and thanks for the update! How did you determine the charger was the cause?
Discussion Starter #8
Honestly, just a guess. I took the receptacle apart and performed continuity testing on the individual contacts. So i assumed the next thing in sequence. I noticed a few on this forum who had similar charging issues who had taken their vehicles in to dealers ended up getting receptacles, on board chargers, and main contractors replaced. I started with the most simple and worked my way, luckily eliminating the second item on my list of suspects. I was also lucky to find it on eBay for $130. Thanks for your assistance and interest.
Ben
Discussion Starter #9
Plus- I have never been so happy to see a working and consistent charge profile!! Unfortunately it is a little cloudy today.
171438
I'm having a similar issue with my 2013 volt. When I plug it in, the charge light stays on for a few seconds, then turns off. There are no codes. I tried using other chargers and it didn't make a difference. The dealership said the drive motor charger cable, receptacle, and housing (22847243, 23281030, 20972413) needed to be replaced so I ordered the parts and replaced them myself but it did not fix the issue. Do you think it's the onboard charger? Also, the battery will charge in mountain mode.
1 - 10 of 10 Posts
