Do you have a 2013 Volt with the MyLink interface (not navigation)?
Do you have a Samsung S3, iPhone5?
Try this.
Pair your phone with your Volt.
Select the phone screen so you can watch the status of the phone.
You should see your phone is connected and an indication of your phone book and call list.
Now drive around while someone observes this screen.
Do you occasionally see the BT connection to your phone drop and then reconnect, usually within a few seconds?
Does the Phone book and/or Call list go away (caused by BT connection dropping and restoring quickly)?
If so, please report it here and let GM know through your service writer, Volt Advisor, or MyLink service.
Mine has been doing this with my Samsung S3 and my wife's iPhone5 since I got it last August.
It was so bad at first that it spent a lot of the time disconnected.
It has gradually gotten better with Volt software, Samsung OS and Apple iOS upgrades but it is still quite common and reproducible.
I suspect it happens when I change cell towers since it tends to happen in the same location each time.
You have to be driving around to see it.
My service writer took her iPhone 4s and tried three other new Volts on the lot and saw the same thing.
Even with that, GM seems to think I am the only one in the world with the problem and they insist on trying to "fix" my car.
They have done numerous software upgrades and replaced the radio with no luck.
Now they are calling in a field engineer to "fix" it.
It sure looks like a Mylink issue, not an issue with my car.
So, please let me know if you see the same thing.
Maybe they will actually start working on the real problem.
Try this.
