After 2 weeks I am very satisfied with my 'fully loaded' 2013 Volt: it drives great, looks good and efficiency is better than the EPA sticker. The drive modes of the Voltec transmission makes this the most advanced and complex car ever, and GM pulled it off. As one review noted, its a giant video game for adults, and I enjoy playing that came on my commute to work.
The complexity inevitably results in bugs and minor design errors. They are the inevitable side effects of large projects. None that I saw until now were bad or affected the core operation or hardware of the Volt. This is the list of software bugs I am experiencing:
Edit a month later: Of the above list of issues, the incorrect date problem and the voice navigation prompt have been resolved by GM as of October 17th. I brought my Volt in for unscheduled service after two check-engine light events. I compiled a full list of issues, and the dealer installed the very latest firmware.
The system date is always one day ahead. This is literally the car of the futureUpdate Oct 18, 2012: Firmware upgrade resolved this problem
The iPhone remoteLink app has a bug that makes it impossible to set charge alerts. That was reported multiple times, but there is no indication that Onstar is working on resolving this. There is a complex work-around. Update October 30th: after some initial trouble, the latest version resolved the issue.
When connecting an iPhone using mylink it sometimes plays though its internal speaker instead of the car's stereo. This could be a bug in iOs or in mylink. Unresolved. There is a hack to correct it when this happens.
Setting the XM music category list has no effect that I could see. You are always scrolling through a flat list of zillions of channels. That makes the setting rather pointless.
There is a setting for the volume of the navigation voice prompt (which works). There is also a setting for the strength of the muting of the regular audio while the computer voice is guiding you. That doesn't work. During nav announcements the radio/postcast is always muted down to an unintelligible level, which is irritating. The only work around seems to be to switch voice guidance off. The nav system in the 7-year old Toyota that I have solved this much more elegantly by outputting the voice guidance only through the left front speaker. Both the Volt and the Toyota's nav are sourced from Denso. Update October 18, 2012: Infotainment firmware update has resolved this problem.
POI name search does not work properly if no city name is entered. One would expect that entering 'starbucks' would yield a sorted list of the nearest SB locations. Instead, it lists hundreds SB locations that are 400 miles away. The work-around is to enter the name of the city one is in. But that excludes SB in adjacent cities that might be closer. Looks like I better use the map app on my smartphone.
