That is BS. They may not know the reason for the problem, but they can certainly see the problem. It's their fault they don't have the proper diagnostic tools. Is there no other dealer to whom you can take it?
That is BS. They may not know the reason for the problem, but they can certainly see the problem. It's their fault they don't have the proper diagnostic tools. Is there no other dealer to whom you can take it?... no ETA on this kit and my car is stuck there and they won't provide a loaner because technically they haven't diagnosed the issue yet.
I completely agree with you there but I don't have much of a choice. I don't want to drive it and them come back at me saying I made it worse by driving it. I'm wondering if since I have a call into the GM customer service line they will cover a rental for me while they get it sorted - this just screams terrible customer service to me if not.That is BS. They may not know the reason for the problem, but they can certainly see the problem. It's their fault they don't have the proper diagnostic tools. Is there no other dealer to whom you can take it?
Well that is not a 12v battery issue.They replaced the charge port yesterday - today leaving for work, car powers off and reboots while driving, lose all power steering/brake assist and a bunch of messages like Engine Not Available, Service Soon; Propulsion Power Reduced; Service Front Camera; Service Charging System, etc lit up. Turn car off and back on, everything is fine. Drive for a few hundred meters and boom, reboots again.
I don't know WTF they did to my car but I had it towed to the dealership.
Note: I don't think it would be a 12v battery issue, I replaced it last month with a brand new one.
EDIT: Uploaded a video of it happening: https://youtu.be/pGGK_IzGWcU
If the dealer didn't torque down the fuse block, why would you need to look to GM for the tow reimbursement? Sounds like a dealer liability to me. Am I missing something?Turns out it was the 12v fuse block. When they disconnected it to replace the charge port it wasn't torqued back to spec and was loose, causing the intermittent loss of power. Makes sense, but crappy. I'm hoping GM will pick up the tab on the towing bill to get me there.
Haha I don't think so either.I don't think that the dealer's Voltec Technician got an A in the course... just guessin'
It's been charging but the MIL is still on. The dealer actually had it all day yesterday and took everything apart, called GM TAC and had an engineer on the phone and they found an issue with the onboard charging unit - they have ordered a replacement that should be here in 2-3 days. I'm really hoping this fixes it but... I won't hold my breath.I hear ya with being at m wits end. I'm struggling so bad right now, I plug in, it goes green I walk away and then get the on star message on my phone "charge interruption" or something like that. ERR I'm getting the codes pod05 and another main one that is on the forum, check out my new thread "no charge saga" for the whole story. ERR how do we fix these issues, it has to be something little. And I don't have a dealer close enough that knows anything so right now I'm forced to dig around on here. Please keep updates comeing thank you, any change as of today/last night in charging?
Thanks - and yeah, I agree. The tech working on my car is a new Volt certified tech so he is going through all of their processes step by step and not really doing any critical thinking.I've got my fingers crossed for you. The Volt is really a fine car that is usually trouble-free. When it goes bad, it is hard to diagnose by someone not trained in doing Voltec repair... it's a new animal. That's why Volts must be worked on only by trained technicians. The Volt Technician has to have native intelligence and be able to think things through, IMHO.
Good luck to you and let us know how things turn out with your problem.
I wouldn't do that. Things might end up with the finding that something else entirely different has caused the problem and then you would have spent many Loonies for nothing. Let things take their course.Thanks - and yeah, I agree. The tech working on my car is a new Volt certified tech so he is going through all of their processes step by step and not really doing any critical thinking.
What I am wondering though - and maybe someone with a little more electrical knowledge can chime in - so he tested the resistance values from the cable that connects the onboard charger to the battery, it was supposed to read infinite (or no) resistance, but one of the legs was 52k ohms - now, this could very well be the onboard charger, but it could also be the HV cable going TO the charger. They are not replacing that cable as far as I am aware. I was actually thinking of just paying the $150 CAD for the cable and have them replace it at the same time just to make sure there are no more issues.
Thoughts?
Thanks and yeah, that sounds like a plan. Still waiting for the part but it's been charging fine the past few days, not to jinx it at all. I'm going to ask them to test the resistances again after replacing the charger just to make sure it's not the cable. The tech who is working on my car is a cool guy so now that I know him I don't think he will have a problem doing it.I wouldn't do that. Things might end up with the finding that something else entirely different has caused the problem and then you would have spent many Loonies for nothing. Let things take their course.
