I bought a beautiful off-lease 2013 Volt that had about 50K miles on it. Checked everything, or so I thought. After the 30-day warranty ran out I discovered that the heated seats don't work. If I push the icon I hear the click sound but the icon bar does not light up. If I go into Climate and push the icon I can see in Climate where it changes from Automatic to Manual so the dash button is registering even though the little light beside the icon does not light up.
Here's what I've done so far to check it:
1. Checked 25 amp use panel - OK
2. Checked under both front seats for signs of loose wiring or loose connectors - everything OK
3. Checked fuse panel under hood to see if there was any secondary fuse - none found
I figure that if I go back to my dealer it's going to be $300 just to drive it into their service bay and I'm not disposed, especially this time of year, to spend hundreds of dollars on a repair for what is, in-essence, a luxury item.
I saw that there was some issue with 2011 Volts, a radio programming function of all things, but mine is a 2013 so I don't think this applies to me..
Any thoughts????
Thanks in advance,
Chris R.
Any thoughts????
Thanks in advance,
Chris R.
