So here is a little curveball for all here:
My wife's 2013 stopped charging on L2 at home ( BOSH), but the other two volts i own ( 2011 and 2012) charge fine on that same BOSH charger.
She was able to charge at work on a ChargePoint for a while after the home BOSH stopped. Eventually - that ability stopped a few days later.
No faults, check engine lights. just says "not able to charge" on the dashboard once plugged in .
I took it to my local dealer where they actually have an excellent voltech mechanic. He confirmed there was no codes, and stated that charging was fine on 3 different L2 chargers he tried.
He recommended trying to clean the plug on the BOSH.
So i did, and now - none of the three volts i own charge on L2.
It appears, my cleaning procedure screwed something up
My question is - does anyone have a remedy, a trick, or a wander cleaning solution to try to bring the charging back to life?
Any help would be greatly appreciated
Peter
Peter
