1 - 2 of 2 Posts
So I got a 2013 and when I was on the freeway got the reduced propulsion and the engine didn't start, so basically I drifted to the next exit and pulled over.
first though was maybe I was low on gas or somehow depleted the battery so much that it just quit, gas was good, the battery was dead.
so when I finally had it towed home I got online here and have seen many have changed the 12v battery and that did the trick, well I changed that out and nothing, same messages. Then I changed out the spark plugs thinking maybe that was the problem, but nothing, I still have the same messages and it seems like it doesn't even try and start the ICE.
Is there some kind of way to reset this so it will at least try and start the ICE?
Anyone out there with the same issues?
Does the engine start when you open the hood?
1 - 2 of 2 Posts
