Hi All, need some advice on making my 2013 Volt base more liveable.
All these annoying tickytacky problems I don't know where to begin and hiring the Dealer or a mechanic could turn into a super expensive repair for these strange yet possibly related problems.
Could there be a module or update that would effect all of this?
Lastly the other issues the car has had was
Thanks in advance for any advice, I am handy and can wrench a bit so will try any suggestions within reason.
- Right lower turning light assembly and maybe harness is bad from being cracked and water damage, not sure if anything is related accept for
- the turn signal fast blinking when turning that way. But other things -
- both side mirror motorized controls do not function, just stopped one day the mechanicals should be fine -
- Interior light will not work when door opens making it difficult to enter and exit at night -
- right rear door indicator shows as ajar always (it is closed) -
- driver's switches for the rear window controls only works on I think the left rear window but both windows operate in unison, cannot be independently operated -
- outside door handle locking button unlocks fine but does not lock the car when pushed, can only lock using the keyfob -
- the passenger airbag failure and warning light and annoying chime, Dealer said the airbag sensor module needs replacing for like $800, of course never used and it failed 3 years ago.
- Other issue is the back brakes on I think all EV's do not get used enough to keep working without getting rusted and they seize up or drag on the rotors. Using regenerating braking makes the brake system lazy and sedentary with eventual corrosion and failure, but not too expensive of a repair, just that one would think the brakes should last forever if they aren't being used.
