I repaired 2 broken regulator tabs, put everything together which was pretty easy since there are only 2 harnesses to plug in, hookup the latch cable and feed the lock through the inside door cover. I checked the window operation and it worked fine, I close the door and notice the lock was not going all the way down in lock position. Then I couldn't open the door, I tried the inside latch, the outside handle, the fob unlock. It looks like something is jamming the lock closed. So now I have to figure out a way to open the door so I can pop the inside cover and take a look. I am open to suggestions but I am thinking I will have to go in the window slot and somehow jimmy the lock (slim jim like), any suggestions on another method to open a locked door?
