1 - 5 of 5 Posts
2013 Volt
Hi all,
My Drive Mode Button seems to be malfunctioning. If you've had this issue do you remember the estimated repair cost?
When I first start the car, pushing the drive mode button works fine. However after about 20 minutes of driving, when I push the drive mode button, usually nothing happens. No menu appears which allows me to alter the drive mode.
Model Year: 2013.
Thanks for any info.
I have taken the front center console off, it takes a flat blade screwdriver and a phillips screwdriver and maybe a 7mm nutdriver, and about one minute of time.
Also, some of the buttons are available on ebay new and cheap.
The button is easy to fix, less than 1 min. Pop off the face by gently using a flat blade screwdriver and after face is off use a small amount of electrical contact cleaner and spray it around the push button. Press it several times. Should work perfect assuming no other damage. Seems the contacts get dirty.
1 - 5 of 5 Posts
