Hi all,
I got a 2013 second hand volt at 140k miles. I just took off the spark plugs myself and realized that they are all ACDelco ones with part number 55585534, or ACDelco 41-122. Can someone tell me if this is the original spark plug or it has been changed.
Thanks!
Update, I did my own spark plug change. Details are here:
Taking out the engine cover, 2 bolts and two air hoses. Then take out the ignition coil and then spark plug.
https://www.youtube.com/watch?v=M-zGJL87Hro
My previous owner had the spark plug changed already, however, the dealer he used put in some bad ACDelco ones that was leaking.
https://www.youtube.com/watch?v=FIhYevf1Klc
I ended up breaking one of the ignition coil boots.
I had to make my own tool to get the broken piece out, it was a 12.7mm outer diameter, ~10 mm inner diameter aluminum tube, flared a little at the top.
We learned the lesson and bought dielectric grease:
https://www.acehardware.com/departm...mR2CTr0ipsWnAen296OBlKRVSk-2XKsRoC3A4QAvD_BwE
The replacement boot can be found at
https://www.oreillyauto.com/detail/...=Ultima+Select+Wires+Coil+On+Plug+Boot&pos=63
$8 each piece, if someone finds a cheaper one, let me know.
Before putting in the spark plug, make sure you have gapped it correctly, the tool is only $5 but in my experience it makes a lot of difference in the engine noise. The gap should be 0.7mm according to the service manual.
https://www.youtube.com/watch?v=9zrH2OQV0P4
The process of putting in the spark plug. The toque required is 216 Lb*in.
https://www.youtube.com/watch?v=60nQqj05nE8
The torque for the ignition coil is 71 lb*in.
https://www.youtube.com/watch?v=hVzefKyVs3Y
Thanks!
