2013 Click from axle when starting and stopping
343 Views 4 Replies 4 Participants Last post by  MikeBCo
clicking when starting or stopping
There is a GM TSB regarding this issue. Many have suggested changing the thrust washer, the axle nut for a larger diameter, retorquing, or changing the entire axle.
Service Bulletin
Bulletin No.: 19-NA-103 Date: May, 2019
basically states remove the thrust washers causing clicking and discard. Do not replace with new washers. Check the ABS sensors for damage And replace if required. Reassemble Using a new axle nut. The torque procedure is not specified but the original final torque is 185ft lbs.
1 - 5 of 5 Posts
Was there a question?
Is the torque procedure the same procedure and final torque?
• First Pass, 150 N·m (111 lb ft)
• Second Pass, Loosen the nut 45 degrees
• Final Pass, 250 N·m (185 lb ft)
1 - 5 of 5 Posts
