1 - 6 of 6 Posts
I was wondering what the charging rate will be if I use a 2013-2017 L1 charger (evse) on a 2012 volt. The 2011-2012 has the button on the charger that selects between 8 and 12 amps. I've read the 2013+ has the selection made on the vehicle's screen.
Will I lose the ability to switch between 8 and 12 amps if I use purchase a 2013+ charger?
Thanks!
Thanks!
Hi silvervolt2012,
We just came across your post and wanted to offer some insight. The 2011-2012 Volt will charge at 12 amps on Level 1. If a different cord set is used you will lose the ability to reduce the charge to 8 amps.
If you have additional questions, please feel free to send us a message.
Best,
Lauren E.
Chevrolet Customer Care
Discussion Starter · #5 ·
Thanks! I'm going to look for a 2011-2012 EVSE then. I want to charge at 8 amp since I don't have a dedicated circuit in my garage. Are there any alternatives or new models of the 2012 evse? It looks like it's discontinued on couple gm parts stores.
If it reasonable to install a 240 V outlet, the 2016-17 Volt EVSE can charge your 2011-12 Volt at 12 A x 240 V, which is almost a 10 mph rate. A NEMA 6-15 (240 V) outlet would require a dedicated breaker and wire run, but the breaker, wire, and outlet are all very inexpensive.
GSP
1 - 6 of 6 Posts
