Hi,
New member here with a 2012 Volt. I purchased this wonderful car last August with a little over 60,000 miles and am currently at 76,645 miles on the odometer. Unfortunately it has recently lost brake assist after a tow (you have to press the brake all the way down to get even a hint of braking force), the e-brake does not engage with the rocker switch, speed is limited to approximately 30MPH, and Service Stabilitrak keeps coming up on the DIC.
I have recently replaced the following front end components:
The last few days the car was not wanting to run on battery power only and kept displaying the "Reduced Propulsion Power" message. I drove it that way until it could not move reliably. The dealer mentioned that the battery pack may need to be replaced, at a cost of $12,100. They did not mention what the braking issues could be, stating that it needs a full diagnosis (but could possibly have been caused by towing it on a rollback with the rear wheels on the ground).
Questions:
1. Could there be possible damage done from towing the car with the rear wheels on the ground? I had the tow driver put the car in Neutral, turn off the e-brake, and left the keys inside the car with the ignition on (assuming the CVT transmission needed its pump running like most automatics). We did not turn off the Traction Control or Stabilitrak systems.
2. Is there a reliable source for aftermarket high-voltage batteries for the Volt? $12,100 seems rather steep and is more than I paid for the car. I would be good with a battery that's 1/2 the cost, but don't know how good the aftermarket batteries are for range and reliability.
The car currently has the following codes:
It is not drivable at all and I would like to get it back on the road soon - when running, it was absolutely the best vehicle I have owned!
Thanks!
- Both CV axles (due to clicking on right turns)
- Both lower control arms (ball joints were shot)
- Left front wheel bearing (to solve "Low Traction" message)
- Both outer tie rod ends, both front struts, and strut mounts.
Questions:
- P1E00
- P0BC5 (Hybrid Battery Temperature Sensor E Circuit High)
- P0C4A (Hybrid Battery Pack Coolant Pump Control Performance)
- P1E00
- C1221
- C1222
- P0BC5 (Hybrid Battery Temperature Sensor E Circuit High) x2
- P0C4A (Hybrid Battery Pack Coolant Pump Control Performance) x2
Thanks!
