$2200? Not $22,000? If true that is amazing. If not it’s a little early for April fools jokes huh?
Can you post the quote?
Ditto, I'd like to see that as well. That price is magnitudes below what everyone else has posted.$2200? Not $22,000? If true that is amazing. If not it’s a little early for April fools jokes huh?
Wondering if this TSB refers to the Kit that Parscom2010 is referring to. If true with my GM employee discount perhaps we are in good shape if our Volts battery diesDitto, I'd like to see that as well. That price is magnitudes below what everyone else has posted.
Uh…this IS gm-volt!Someone has done a writeup on a DIY battery replacement. If you do some googling you should be able to find it. It might be on gm-volt instead of here
I had a battery replacement done for my 2012 Volt by Greentec, about a year ago, for $8,000 (not including tax). It would have cost at least $12,000 at the dealer (I inquired at 2 different dealers). I suspect the Service Advisor meant $12,000. Importantly, the battery pack is refurbished. It is NOT new. It gets about a third less miles per charge than the original battery did, which has been quite disappointing. However, it has been a great car, is good enough for now, and I'm babying it along, as each new year of electric cars brings significantly better electric miles, at lower cost, with more features (incl V2G and better replacement/recycling options).Hi,
My 2012 Volt's big battery finally went dead. 3 cells are no good. Chevrolet has a program to replace the whole battery pack with a refurbished battery pack. According to the Service Advisor, they did a similar one last month and cost about the $2200. I am very happy there is a way to save the car. I just wanted to see if Other folks have had this type of replacement/repair done and how was their experience. I am not sure how much warranty is available with this refurbished battery. I will let you know how the repair goes. It will take 4 to 8 weeks to get the car back. I am here in the Dallas area.
Give me a month and I will let you know how it went. I am also shocked at the $2200 quoted. They told me about a month before somebody had done the same repair for $1200 and with everything the price came to $2200. This is of course a refurbished battery they will replace mine with. The Service advisor told me at least 1 month up to 2 month before i will get the car back. He told me Chevrolet is doing this so they won't get a bad reputation on these cars. This is another company in OK which has contracted for these battery repairs for both Volts and Bolts....I hope it is true and I will definitively let everyone know the results. I have recommended this volt to 5 of my friends so I am very anxious how this will go. Even if the car is good for another 3 years....it will be worth the $2K cost. I hope this repair part of their business will take off; i want them to make money and it will give more life for these wonderful volts...
Hi,
Hi JAF,Have a 2012 Volt with 150,000 miles with 2 week cells.
Have been driving in mountain mode.
I start with a fully charged high voltage battery and a fully charged 12volt battery (trickled charged)
While fully charged and plugged in to 220 v charger I start car and raise hood.
This will start gas engine generator.
Unplug high volt and 12 volt battery and drive in mountain mode.
This has worked so far.
Down side is lower range and more time the engine generator running.
If you drive aggressively you may get a low power warning light and a check engine light.
if you do I recommend you go back to your house with out shutting down the car.
To reset check engine light I plug in car to recharge and start it. While running raise the hood and start engine. This will allow the check engine light to reset.
If you shut down the car away from a charger it may not restart. Call a tow truck and take to a dealer to reset check engine light. Dealer will try got sell you a battery replacement.
This means )most likely you a couple of week cells in high volt battery. I said no thank you just reset check engine light and verify the battery will recharge.
I took the car home and put another 30,000 miles on it.
Do not ask me why this works. People that are smarter than me may be able to explain why this works.
My guess is Mountain mode balances an charges the bad cells and allows the engine to start in mountain mode and keeps a buffer charge in high volt battery.
Usually it's whatever their minimum shop time is, typically an hour. How much that costs will vary shop to shop, but I'd be surprised if it's less than $120 or more than $250.Hi JAF,
I'm so glad to read your post. I also have a 2012 Volt with 167K with weak cells and had three times that my Volt couldn't start the engine due to low power warning. I use the same way like you did to deal with this condition. But each time I asked my son to reset the "check engine light" instead go to the dealership. Unfortunately my son is not available now. My question is how much the dealership charged you to reset the "check engine light" and verify the battery will recharge.
Michael
Just remember that them not being aware of a program doesn't mean that there's no program. They probably just haven't been called upon to look yet.I have a 2012 Volt (200k) with a few weak cells and after reading your post, I called a few of my dealers here in Central Florida. They weren't aware of any program, but I hope that will change in the future.
Hi,
Spiers appears to be a Ney-der-laan-der and has teamed up with Cox Automotive Mobility...a mongo company. Gotta love the Dutch for business sense.
Maybe they will become the modern day Jasper...EV rather than ICE. They have had no problem getting financed and are expanding their locations and sqft.
Cox Automotive Mobility and Spiers New Technologies Expand Global EV Battery Service Network - Cox Automotive Inc.
