1 - 20 of 522 Posts
2012 Volt with almost all options including Nav, #105788.
A picture is worth a thousand words:
Electronics Multimedia Technology Vehicle Car
Am out of the country currently, my wife will have to bring it in after dropping the kids off at the daycare.
Will update when I have more information. Am grateful that we decided to lease at this point.
*Edit: We just picked the car up Saturday evening (4/14). Car was running fine even with the error message, except no charging was possible.
*Edit2: Turned out to be a leaking battery coolant pump which was replaced under warranty. Great service from Volt advisor and Terry Thompson Chevrolet made the situation much easier to get through in the end. Repair took 2 days.
Call a volt adviser ASAP. They can help align the stars for your wife.
Press your OnStar button now!
...and get the insights OnStar people can give you. Talk with a Volt Advisor. Copy down the error codes.
If GM thinks it's safe, try restarting your car a few times. Try plugging in and unplugging the Volt.
This sounds like an issue that will require servicing though. Here's hoping the fix is rapid and you get back to enjoying the car promptly.
WOW, I hope this was either a simple anomaly or an easy dealer fix. I assume you weren't stranded and the car got you home safe and sound?
That seriously sucks. I hope it's something trivial.
Didn't we have someone else who had that problem and it was one of the logic boards in the battery assembly that had to be replaced?
@ chan25,
Very sorry to hear you this. I do want to apologize for the inconvenience. I see your Volt is now at the dealer and one of our advisors, Kevin, has spoken with both you and your wife. We are keeping an eye on this and will work with the dealer to get you back you guys back in your Volt as soon as possible.
@ chan25,
This.... is pure and simply amazing - response like this was impossible before the net and owner/enthusiast websites like GM-volt.com. Kudos to Chevy/GM for monitoring things here. Good luck on this fix, and keep us posted with a follow up.
According to my dealer, it was the coolant pump. Not sure how that made the high voltage charging system fail though.
Part should be in by tomorrow, and they are estimating the Volt will be ready for pickup some time on Friday. Will update when possible.
PS: Kevin, my Volt advisor, has been sending me updates via email. Excellent service so far.
@ chan25,
I spoke with Kevin again and it looks like your Volt will be ready as early as Friday, so that is very good news. I will definitely pass your kind words along to him!
Discussion Starter · #10 ·
The car was just delivered to my house and is charging fine at this moment.
It turned out to be a leaking battery coolant pump, which has since been replaced. Everything was fully covered under warranty.
Thank you's are due to my Volt advisor and Terry Thompson Chevrolet who handled everything really well. My wife was really pleased with the level of customer service and asked me to be sure to let everyone on this forum know.
@ chan25,
Awesome! Great to hear! I will be sure to pass your thanks along!
Thanks for the update chan25, glad the problem was promptly solved. May you now enjoy your Volt as it was meant to be!
I have the same error: "Service High Voltage Charging System". We shall see if it is the same coolant leak as chan25 was told or something different. The error appeared after I used the parking brake. I have about 4,700 miles on the car and nothing has been wrong with it so far. I recently had the recall warranty service so I am suspicious that the dealer did not put things back 100% correctly....
Update: this was fixed in a day at the dealer. No major issue. A coolant problem that may have resulted from the coolant line not being fully bled (something about there being a bubble in the line). Unclear whether this could have been caused by the recall service. If so then the techs need to watch out for this....or perhaps just an isolated incident.
Sorry to hear about this issue you have run into. Have you taken your Volt into the dealer yet? If not, give us a call and we can get a service appointment set up for you.
As scary as that message is, I'm betting it all has to do with insuring the integrity of the cooling system for the battery and the battery itself. There is a member here who had a leaking coolant system, and it took out his battery. Also, the government induced "Thermal Event" had to due with leaky fluid. An inconvenience now, but could save everyone a whole lot of hassle and money down the road.
Experiencing the same "Service high voltage charging system" along with a check engine light at 442 miles. Very disappointed. Three weeks old and dead car. OnStar was not very helpful, spoke with four different "OnStar Advisors" and gave my information to each one. Finally decided to call dealership, was told they may be able to get to it sometime in the next few days........Reminding me of a GM diesel I owned in the 80's. Not a happy Volt owner!
I don't have much faith in the dealership I purchased from in being able to repair the car, they told me they haven't had one in for service and were not sure if they had a trained tech as of yet.
Have not been contacted by a Volt Advisor since purchase, perhaps it is too soon (5/26/12 purchase date).
Received a call from OnStar this past evening asking how my service was progressing, told them it wasn't and was transferred to a supervisor that began the call by asking for all of my information again....... No progress there for sure..
Anybody in the Tulsa Oklahoma area that has a good experience with a dealership service department? Would like to get this vehicle in for diagnosis with someone that has been properly trained.
Dead VOLT in garage day two
@ Okbeartoy,
I do want to sincerely apologize for your frustrations. Please send me a PM with your contact information and last 8 of your VIN and I will have one of our advisors get into contact with you and we can assist you in getting everything taken care of.
Filling radiators (which the battery cooling system is) can be a hit & miss affair. Often times, they have an air pocket after the fill, and they don't burp until driven down the road, or they get hot and circulate. I bet a lot of these errors are because after the battery shield install, the coolant is refilled, and they burped. This triggers the coolant level sensor and CEL error.
Many complicated cooling systems (motorcycles) require a vacuum fill technique to avoid air pockets.
There is a procedure listed for filling this part of the system on the GM Techlink site. Procedure indicates that a special vacuum cap is used to apply vacuum to system and then refill as needed in a procedure that could last over an hour.
1 - 20 of 522 Posts
