Googling the bearing and seal part numbers listed in the PIP finds that you can get both for about $100. So, labor would be $2260. I have read on this forum that the work takes less than a day to do, so at 8 hours that is $282.50 per hour.I wonder how much that part costs and how much is labor.
So the parts are inexpensive as parts go. The labor is very intensive.They have to disassemble the left front suspension to get at it. Then the actual bearing R&R is done with a specific press tool. I would want the documented procedure followed to a T with proper tools etc. My 2011 was done twice and each time I looked at the disassemble, pretty complex. The first time it was done the technician left a motor mount bolt loose. That created a strange clunk which took 3 trips in to finally find.
I had front brake rotors on a car replaced under waranty once and the tech left a caliper bolt loose which allowed the caliper to come loose and puncture the tire rim. Luckily it was in town and didn't kill me.They have to disassemble the left front suspension to get at it. Then the actual bearing R&R is done with a specific press tool. I would want the documented procedure followed to a T with proper tools etc. My 2011 was done twice and each time I looked at the disassemble, pretty complex. The first time it was done the technician left a motor mount bolt loose. That created a strange clunk which took 3 trips in to finally find.
I had that bearing work done on my 2011 for around $1500 in late 2019. That included a new motor cover (around $300) which is not always needed. The price did not include the bearing itself. I had ordered it thinking I might do the work myself, but once I learned about the special tool caronjeff mentions above, I bailed. The dealership (Bill Crispin in Saline, MI) was good about installing the bearing I'd bought. You do get a coolant change as part of the process.They have to disassemble the left front suspension to get at it. Then the actual bearing R&R is done with a specific press tool. I would want the documented procedure followed to a T with proper tools etc. My 2011 was done twice and each time I looked at the disassemble, pretty complex. The first time it was done the technician left a motor mount bolt loose. That created a strange clunk which took 3 trips in to finally find.
