Painfully obvious. The question was in regards to a way to automatically handle this. Thanks for your time though, albeit confusing why you took it.Just turn the fan up.
Yes, I too manually increase the speed but this takes away from the "hands free" element and thought there might be a solution.On my 2012 I'm not aware of a way to disable that feature, but it's possible to manually increase the fan speed so I just do that.
Good suggestion on the Bluetooth part. I see you're in Tenn. so you can understand the terrible humid heat we have in the southeast...and you're right on the money with the second sentence. It seems I wait to make calls until I get to my car OR I always get called when I get in my car and its very hot. I'll have to be more cognoscent of pre-cooling my car moving forward, I think that may be the best solution.I know this is not really the answer you seek, but it is another way to work around your issue. When It's hot and you don't want the fan speed to drop, right after you make the call, using the dial pad of your phone press the Bluetooth button to turn it off. This will disconnect your phone from your car for this one call only. The next time you make a call it will connect up as normal. Of course the downside is during this call you will have to use your handset for the call, instead of the hands free through the audio system of the car.
Perhaps like me, when you first get in the car it's hot and you want it to cool down quickly, but you need to make a call. This way you can stay parked while you make the call while the car is cooling down.
Flip-side is you can use your phone's app to pre-cool your car 10 minutes before you get in. With the car already cooled down a drop in fan speed may not be a big deal.
Not sure why you're wasting your time here...again, the reason I ask is because I've had my car three weeks and I didn't know If I was overlooking a setting. Clearly, the purpose of "hands free Bluetooth" is slightly diminished when I have to reach forward during every call and turn my AC back up during my calls. No, I'm not too lazy to do it, but I do find it annoying that it goes almost all the way down. So to your point, that is much more than "one push" its actually three to four.Literally one push of the fan button puts it back to normal speed operation, is that so hard? When the weather is mild I appreciate the automatic quieting feature, it would be more hassle to turn that feature on and off than it is to simply hit the fan button when you want the fan to stay at speed.
I utilize this fairly often... It does help but in 100 degree/100% humidity south and being that I have had my Volt 3 weeks, I just thought there may be an actual solution to the topic.If you're in range of the car (say, within 100 ft) a few minutes in advance of getting in, you can roll all of the windows down by holding the unlock button down on your remote fob for a few seconds.
Just a few minutes with the car windows open before you get in can make a difference.
AppState08Ok, I've searched high and low for an answer here and there's no good way to search for this! (Too long of a thread to search!)
Is there ANY way to turn off the feature that slows down the AC fan when a call comes in or goes out?
You and you alone manage when you are on the phone.... you have to set your priorities, and not let others or generational custom do it for you:.... It seems I wait to make calls until I get to my car OR I always get called when I get in my car and its very hot... ..
Please do not waste development time with this. I'd much rather have the ability to keep the radio on while on a phone call then bother with a feature that is so easily overridden. If I'm listening to an important weather, news or traffic alert, and get a call from my panic'd wife, I don't want the radio to go dead while on the call; and there's NO WAY to override this like there is with the fan volume adjustment.AppState08
Unfortunately there is no feature to adjust for the option that you are looking for in the climate setting with the Bluetooth.
Feedback from customers, such as you, is very helpful to us. I have documented your concern and will be forwarding your comments to the appropriate department for their consideration.
If you have any questions, please do not hesitate to contact one of our Electric Vehicle Advisors at 877-486-5846. Electric Vehicle Advisors are available Monday through Friday 8:00 am – 9:00 pm, and Saturday 11:00 am – 8:00 pm Eastern Time
Melissa Electric Vehicle Advisor Team
Volt Line: 877-486-5846
Spark Line: 855-477-2754
ELR Concierge: 855-463-6357
Email: [email protected]
They shouldn't. Mine didn't. Try a different dealer. Call the Volt Adviser.Which, on a totally different subject, for another thread, why does Chevy charge for installing the software updates? I just learned that bit, too, yesterday. $70 to have the dealer mechanic plug a usb in an zap the latest firmware....
