So my Volt had some worn out front struts & sway bar links, I had the links replaced & the right front strut was replaced but had to wait several weeks for the left strut assembly to arrive. I needed my vehicle so I briefly drove & found out that the new right strut was a defective part and would make a very loud creaking noise when turning the wheel (in any direction), another side effect was the bolt on top of the strut loosen itself when the wheel was turned.
The car went back into the shop a few days ago and the left strut was replaced, along with another new right strut. What I've noticed now a few days later is that when I turn the wheel lock to lock in either direction there is still a creaking noise (however much quieter). I opened the hood and turned the wheel while looking at the left strut since you can see the strut bolt. There was no movement in the bolt itself but I did notice that the entire assembly seemed to push up/down a tiny bit with the turn of the wheel. There is no noise going over bumps & I can only hear the noise at low speeds & when the wheel is turned closer to lock.
I haven't called the dealer back yet to have it looked at- again.. I read a few old forum posts about people having similar issues like this back when the cars were new, but I'll be baffled if something is wrong with the strut assemblies again, or maybe it could possibly be something else? I don't know, just frustrated after spending $1,286 (cad). Replacing worn out parts with new ones has seemed to cause me more issues lol..
