Hello all. I'm a relatively new volt owner. I purchased a used chevy volt this past june. around the middle of november i got the service high voltage charging system message on my car, and i took it to the chevy dealer. I had read some forum posts saying that it could just need an update to the software, and that's what the service tech did. It charged again and I brought it home.
A month later in december it did it again. I had read about the defeat plug for the coolant sensor so I purchased that and was going to install it after taking it into the dealer once again to update the software and clear the code. due to winter weather i wasn't able to get my car into the dealer until mid January. When i did get it there (about an hours drive from home) they said that they needed to keep it overnight, and they ended up keeping it 7 days. I finally got a call saying that the high voltage battery needed to be replaced. I've attached photos of the notes that the service tech did. the first from november when he fixed it and the second from january when I was told that the battery needed replacing for $10,200.
I declined the battery replacement, as thats about $100 less than what i paid for the car.
I was in despair for a while. I made a post on the reddit volt sub asking what to do.
A few users mentioned that if the battery were truly bad that I wouldn't have been able to drive it on gasoline, and that many times thats the response when either they don't know what to do,or its a go away tactic.
I had spoken with the service tech both times and he seemed pretty forthcoming on all of the steps that he had to do and what the step by step process was that gm had him follow. It also sounded like he had to call or be in contact with someone at GM in order to do the steps for troubleshooting some of the times.
Some redditors advised me to check with an obd2 scanner some things. I didn't have one so I ordered one online. I purchased the OBDLink MX+ OBD2 Bluetooth Scanner for iPhone, Android, and Windows after looking on this forum for recommended scanners.
It will arrive later today. I don't know what apps I need exactly. I've been reading some posts and I have seen some like my green volt app.
What other apps do I need to get in order to help diagnose my 2012 volt battery problems?
I hope that I can get this all sorted out so I can charge the battery again as I very much like the car and have not had it very long.
