Hello
First let me say that I tried finding a similar issue in the forum but didn’t find any posts.
I recently purchased a 2011 volt with 90000 that has a salvage title. I at the time of purchase thought I was getting a good deal, the only thing was the previous owner had it for a couple years and had never tried charging it. According to him he liked the performance and economy without plugging it in, therefore he didn’t have and had never had a charger. So I purchased it without ever plugging it in, the same day I purchased a 110v charger and tried it and it did not charge. Not only did it not charge but it threw a code P1EC5. I cleared the code and immediately went to two different charging stations with level 2 charging. I reset the codes before charging and plugged it in and immediately it set off the same code and the charging station said it could not communicate with the car.
Next I googled the code and it said battery heater resistor stuck open I believe, so I tracked down a used set of heater valves and control module and replaced it. I then hired a programmer to configure the used parts to communicate with the rest of the car. After all that the car still will not charge. Same code keeps popping up, if I clear and don’t try charging the code doesn’t come back and the car just drives using the engine with very poor fuel economy like 20mpg.
I need help or advice, I am struggling financially so taking it to the dealer is probably not in cards for me in the immediate future. I am hoping someone with a similar experience might lead me in the right direction to figure this out.
