1 - 20 of 20 Posts
Below is the Scheduled Maintenance for the Volt from the 2011 Owners Manual (via GM Global Service Information)
2011 Volt Owner's Manual Required Services said:
Every Month
• Engine oil level check. See Engine Oil .
• Engine, power electronics, and high voltage battery pack coolant level checks. See Cooling System for more information.
• Fluids visual leak check. A leak in any system must be repaired and the fluid level checked.
• Windshield washer fluid level check. See Washer Fluid .
• Tire inflation check. See Tire Pressure .
• Tire wear inspection. See Tire Inspection .
Every 12 000 km/7,500 mi
• Rotate tires. See Tire Rotation .
Every 24 000 km/15,000 mi
• Check the engine oil filter for corrosion if driving in a corrosive environment, such as areas of high humidity, along an ocean coast, and/or areas that apply road salt during winter. Have the engine oil and filter changed if the filter shows signs of corrosion. After each oil and filter change, the oil life system must be reset. See Engine Oil Life System .
• Cooling systems inspection. Visually inspect the hoses, pipes, fittings, and clamps. Replace, if needed.
• Windshield wiper blade inspection for wear, cracking, or contamination and windshield and wiper blade cleaning, if contaminated. See Exterior Care . Worn or damaged wiper blade replacement. See Wiper Blade Replacement .
• Engine air cleaner filter inspection. See Engine Air Cleaner/Filter .
• Brake system inspection. See your dealer.
• Steering and suspension inspection. Visual inspection for damaged, loose, or missing parts or signs of wear.
• Body hinges and latches and key lock cylinders lubrication. See Recommended Fluids and Lubricants . More frequent lubrication may be required when the vehicle is exposed to a corrosive environment, such as areas of high humidity, along an ocean coast, and/or areas that apply road salt during winter. Applying silicone grease on weatherstrips with a clean cloth makes them last longer, seal better, and not stick or squeak.
• Restraint system component check. See Safety System Check .
• Fuel system inspection for damage or leaks.
• Exhaust system and nearby heat shields inspection for loose or damaged components.
• See Propulsion System Start Check .
• See Electric Drive Unit Shift Lock Control Function Check .
• See Park Brake and P (Park) Mechanism Check .
• Cooling systems check. See Cooling System .
• Accelerator pedal check for damage, high effort, or binding. Replace if needed.
• Check the sealant expiration date printed on the instruction label of the tire sealant and compressor kit. See Tire Sealant and Compressor Kit .
• Hood/Decklid/Liftgate Support Gas Strut Service: Visually inspect gas strut, if equipped, for signs of wear, cracks, or other damage. Check the hold open ability of the gas strut. Contact your dealer if service is required.
Every 24 Months or When the Change Engine Oil Soon Message Displays
• Every 24 months or when the CHANGE ENGINE OIL SOON message displays, change the engine oil and filter as soon as possible, within the next 1 000 km/600 mi. The engine oil and filter must be changed at least once every 24 months. After each oil and filter change, the oil life system must be reset. See Engine Oil Life System . More frequent changes may be required when the vehicle is exposed to a corrosive environment, such as areas of high humidity, along an ocean coast, and/or areas that apply road salt during winter.
Your dealer has trained service technicians who will perform this work and reset the system. If the engine oil life system is reset accidentally, service the vehicle within 5 000 km/3,000 mi since the last service. Reset the oil life system whenever the oil is changed.
Every 80 000 km/50,000 mi
• Engine air cleaner filter replacement.
• Evaporative control system inspection. Check all fuel and vapor lines and hoses for proper hook-up, routing, and condition. Check that the purge valve, if the vehicle has one, works properly. Replace as needed. An Emission Control Service. The U.S. Environmental Protection Agency or the California Air Resources Board has determined that the failure to perform this maintenance item will not nullify the emission warranty or limit recall liability prior to the completion of the vehicle's useful life. We, however, urge that all recommended maintenance services be performed at the indicated intervals and the maintenance be recorded.
Every 160 000 km/100,000 mi
• Spark plug replacement. An Emission Control Service.
Every 240 000 km/150,000 mi or every 5 years, whichever occurs first
• Engine cooling system drain, flush, and refill (or every five years, whichever occurs first). See Cooling System . An Emission Control Service.
Every 240 000 km/150,000 mi or every 10 years, whichever occurs first
• Engine drive belt inspection for fraying, excessive cracks, or obvious damage. Replace, if needed.
Every 10 Years
• Air conditioning system flush and refill and desiccant replacement.
Humm, No cabin air filter??
So, I assume "• Cooling systems check. See Cooling System." is the battery cooling system, since at 100K miles is "• Engine cooling system drain, flush, and refill (or every five years, whichever occurs first)."
Actually the reason why the cabin filter isnt mentioned is it doesnt have one. (at least from factory) But there is a filter that technically fits both the Volt and the Cruze soon to be released, so consider it "optional" equipment. ;)
Typically the cabin filter replacement schedule is every 25,000 miles (40,000km) or every 24 months, whichever occurs first. However it might require more frequent replacement if you drive in areas with consistantly heavy traffic, areas with poor air quality, or high dust levels (gravel roads). Replacement may also be neccessay anytime there's a noticable reduction of air flow, poor window defogging, or odors.
On the "Coolant System Check" That's service just an underhood level check of the THREE coolant reservoirs (ICE, Power Electronics, Battery) and a visual inspection of the radiators, hoses,pumps,and fittings for any signs of coolant leakage.
HTH
WOT
I think there is really one important things missing from the schedule / and the GM manual which really suprises me from GM.
1st. 2 Year brake fluid changes.
Brake Fluid Dot3 is hydroscopic ie: it absorbs water leading to sooner brake fade under harsh conditions and then latter
corrosion of brake components (Expensive ABS, Master Cyclinder and wheel calipers / wheel cyclinders)
2nd. Engine Coolant bleeding procedure for when the engine resovoir is empty.
Remember on this vehicle it is a tough job as the engine appears to sit higher than the coolant resovoir - making this very important to do this right otherwise cracked head gaskets etc. $$ could result. It's not like you can baby it like in a conventional car the power train brain will show no mercy until it overheats.
3rd ICE/Power Battery Coolant change replacement / bleed procedures when your not at a GM dealer in emergency.
In the real world even if rare leaks can a do occur and hence it would be of reassurance to me to have this extra information.
Otherwise a very well layed out informative owners manual.
Regards,
Martin
I have never seen an American car manufacturer recommend brake fluid changes. They surely should, but they don't. I always change my vehicles brake fluid every 30,000 miles. The old stuff comes out a rusty orange and the new fluid is clear. Bleeding air from the anti-freeze is not a time dated maintenance item. It is a procedure that is a necessary when changing coolant in cars where the engine is higher than the coolant filler.
Discussion Starter · #6 · (Edited)
Regards,
Martin
Duplicate post
See responses to all 3 of your concerns in this link
http://gm-volt.com/forum/showthread.php?7066-Update-Owners-manual-servicing-information
WOT
I've added WopOnTour's post above to the FAQ. Thanks WVhybrid for the tip via PM!
If anyone knows of changes to this for MY 2012 Volts, please post here.
FYI, I'll be auditing and improving the FAQ next month. 2011 has been crazy for me, but it's getting better now.
Shouldn't all the mileage intervals be tied to EV, ICE, or total vehicle miles? Why would I change the engine air filter if it hasn't breathed in more than 20-30% of the total miles?
^ good point voltage, also in the prius after 4 years I believe a member tested his brake fluid for hydroscopicness and found out that the brake fluid was still good because of all the regenative braking! It seems when you dont' use the friction brakes a lot, the fluid doesn't have a chance to get hot, so in theory not being able to absorb water as much :O
Kinda reviving this thread... Moving forward with Maintenance, What has everyone "Had" to do other than a few oil changes with their VOLT's? I picked up a MY13 last week, and figured they had an all inclusive package for $720 which included all maintenance for 4years 48000 miles, oil changes, fluids, brakes, tire rotations, etc. But after closely looking at this and doing my own tire rotations and only having the dealer change the oil (thats 6-7 fully synthetic at $59.99 each) thats roughly $330. way less than $720. I think I got conned into the package and no where have I seen any battery testing or VOLT centric/specific maintenance. Kinda Crazy if you ask me but it seems like basically the same schedule as a normal ICE car.
I'll give you the OEM perspective. We're working to eliminate maintenance. Coolant for life, oil for life, etc. Are we there yet, no. But it's certainly a goal. From my perspective, the goal is to repair damage and to not have anything break or wear out in normal use.
From your mouth to the car god's ear.
That is a very admirable goal, however I have always been wary of "life-time fills" for any of the fluids. Like you said, we aren't there yet. The "life-time" just varies so much from vehicle to vehicle, even with what is considered "normal" use varies from a rural town to LA. But, if you guys can work with the fluid engineers and manage it, I'm cheering you on!
Sounds like a great plan - because every time anyone fails to perform requested scheduled work or do it in way incorrectly / carelessly may induce more problems - on a car that was built perfectly.
PS
did an early oil change on my Volt as I never like new engines not getting one, I was plesantly suprised on the autopsy on my Volts very first oil filter. There was no swarf, no paint, could not see any decent copper / bronze flakes....
First time EVER I've wasted my time doing an early oil change.
Very impressed with how clean the engine / engine filter was.
I wonder ...... does it have a different filter or hooked up to a plant system when initially run up - or am Iam i just lucky I got the cleanest built engine ever in any car our family has ever owned?
Any how ... Well done...
Banned
This reminds me, I need to get the tire rotation done. I'm at almost 9k miles now. The dealer threw in free maintenance for the first year of ownership. Just need to find time to stop by the dealership.
Nope nothing special other than GM has improved our cleanliness a lot over the years. The engine is assembled from clean parts, filled with fluids and cold motored in the plant to test it. It doesn't even see fuel until it's in the vehicle.
My 2013 manual states that engine break-in is done as part of the assembly process, so no special early oil change is needed. Maybe this is why?
Lifetime, sure and I have a bridge to sell
Lifetime fluids are not "lifetime" as we know it. The auto industries lifetime is the duration of the warranty period for the particular component - nothing more and nothing less.
Nope not true. I can tell you that systems I work on, we don't even talk about warranty period. We design and validate for the life of the vehicle except for things that do get replaced like wiper blades.
If you are curious buy a copy of a test spec like GMW3155. http://engineers.ihs.com/document/abstract/MNRXXAAAAAAAAAAA
Read that and tell me we test Powertrain components for a 5 year 100K mile lifetime.
pete,
So what exactly is the 'Official Life of the Vehicle' ? Is it 100K miles? That would be bad because I'm considering buying a high mileage Volt, 72K miles.
I do know one of the first things I would do is change the ATF and have an oil analysis done on the old stuff.
I'm sure 100k change intervals are way too long.
The transaxle in the Volt is way more complicated than a Prius. I did an ATF change on my '10 Prius at 112K miles and it needed to be done much sooner. It is posted in Priuschat. It's a bit wordy but just look at the .pdf of the oil analyses.
http://priuschat.com/threads/atf-fluid-changes-are-required.119530/
It looks like the Volt has an ATF filter but it can't be changed without splitting the case, is this true?
Yep, I'm excited about selling my low-tech Prius and buying the Highest-Tech car on the road today, The VOLT !!!
1 - 20 of 20 Posts
