Been wanting to split my 40A circuit for a while. I have two 40A 240V circuits in the garage but one is for the garage heater. I use it for my second Volt most of the year but in the winter I have to choose between L1 and L2. No more.
Decided to create a portable sub-panel. Started off with only going to have two double pole 20 A breakers, one for each Volt. That would have cost me about $80. But I decided to add a single pole 20 A 120V connection in case I wanted to use it in the garage when not charging the two Volts.
Below are the parts. Found a nice plastic sub-panel reasonably priced at Home Depot. It is a good start for the project. Here are the parts, prices and links. Also pictures.
1 TPL412CP 125 AMPS MainLug Indoor PowerMark Gold - $16.77 (HD)
1 GE 1 Pole 20 AMP THQP 120 - $3.94 (HD) only need for 120V setup
2 GE 2 Pole 20 AMP THQP 220 – $8.98 ea. (HD)
1 TGL2P Ground Kit - $4.88 (HD) only need for 120V setup
4 Wire 14-50 Oven Cord 6 ft - $18.99 (Amazon)
1 20 AMP Straight Blade Connector 120 V – $17.97 (HD) only need for 120V setup
3 ft. 10/3 SJOOW cord - ~$1.80 ft (HD)
2 ft. 12/3 SJOOW cord - ~$1.50 ft (HD) only need for 120V setup
PG19 Cable Connectors - $8.99 (pkg 10) (Amazon)
PG29 Cable Connectors - $4.99 (pkg 2) (Amazon)
2 NEMA L6-30 30 AMP 250V connector - $3.00 Ea. (ebay)
Total $110 with 20 AMP 120 V
Total $80 W/O 20 AMP 120V
