1 - 8 of 8 Posts
G
I've been looking everywhere for a set of 17" steel wheels to use for my winter tires, and so far have come up pretty much empty handed. I wanted to stay OE, but the only 17" steel wheels I could find that looked close are the 2014-2016 Impala W-body police package wheels. They're 17x7 with a 5x115 bolt pattern but they're very hard to find.
My search led to these babies:
https://www.jegs.com/i/Cragar/260/83-7718/10002/-1
17x7, 5x115 bolt pattern, +38MM offset just like stock. With the online coupon and free shipping, these come in at $46.99/ea, which is a crazy good deal. Can anyone see an issue with these? If not, they'll probably be on the truck before the end of the week for that price.
2014 Cadillac ELR
I'm sure you know this, but in case not: you can use 16" on Volt for winter steelies.
I used to use steelies on previous car's, but for the Volt I bought aluminum wheels from TireRack. They were $99 each, came with the TPMS and tires mounted, balanced, ready to bolt on the car. Yes, twice the price, but they look nice. I suspect they are a bit lighter than the steel wheels as well. Just the snow tires alone will knock off about 5 miles from battery range.
I bought custom wheels from TireRack.com and used my OEMs rims for my snows. I even went so far as to add 18" rims, a new set of Yokohama Avid Ascends, and a new set of TPMS. I know this is significantly more than steelies, but you need tires (eventually) and a second set of TPMS anyway, so the difference between steelies and custom wheels really isn't that much, plus the change in look was well worth it to me.
G
I might consider going to a different size later, for now my stock 17's are in great shape so I plan on removing those before winter and cleaning them up really well while I have them off. The summer tires are practically brand new, as are the snows so I won't be buying tires for several years.
2014 Cadillac ELR
If I had a set of 17" winter tires that needed wheels, I'd buy used OEM Impala (etc) aluminum wheels off kijiji/craigslist. Should be the same or less money than new steel.
G
I keep watching the ad's, but every time I find something the person wants stupid money for them. I'm not paying $50 a wheel for crummy, used aluminum.
1 - 8 of 8 Posts
