NOTE: This bulletin ONLY applies to 2017 Bolts equipped with Side Active Safety Obstacle Detection Enhanced (RPO UKC)
NOTE: This condition may potentially be experienced after rear fascia removal/reinstallation or rear fascia replacement.
Condition/Concern- Some customers may comment when driving, the side mirror indicates there is a vehicle present when there actually is not
Root Cause- This condition may be due to missing aluminum butyl tape that is located on the bottom of both left and right object sensing alert module bracket. This tape is important to the performance of the module object sensing.
Corrective measures- Install specialized aluminum butyl tape patches on the bottom of the object sensing alert module brackets. Use PN# 42563361 (LH) and 42563362 (RH)
WOT
WOT
