Recently posted as an informational bulletin
WOT
WOT
Yes, it is maintenance free until it dies - which it will. It is a lead-acid battery and will fail and have to be replaced in 4 years, like most lead-acid batteries. I'd bet just about every Volt made before 2013 has had its original 12 volt battery replaced. For some - the lucky owners- the Volt's computers provided a warning. Many have failed with zero warning and required either an emergency jump (not always successful) or a tow back to the dealer for service. I for one believe that "replace 12 volt battery" should be a GM-recommended service at 42 months in the owners manual - if it hasn't failed by then, it will soon. it can save the owner a lot of grief.Didn't know it was AGM, nice to know... truly maintenance free!
If it's anything like Volt, the power unit (that charges the 12v battery) puts out enough amps to easily jump start most ICE vehicles.It is ironic that they rate the Bolt's 12 VDC battery with "CCA" (cold-cranking amps). Continuing with the traditional lead-acid battery in BEV's, rated to crank an engine and with less than half the life of the HV battery pack - only makes sense if the industry sees the need for a BEV to be able to jump-start a conventional ICE vehicle.
MY2013 and onward trickle charged the 12V while plugged in. I wonder if that reduced the failure rate of those AGM 12V batteries or at least allowed owners to get a few more years out of them? I have a 2013 with 50k miles and still on the original 12v battery.Yes, it is maintenance free until it dies - which it will. It is a lead-acid battery and will fail and have to be replaced in 4 years, like most lead-acid batteries. I'd bet just about every Volt made before 2013 has had its original 12 volt battery replaced. For some - the lucky owners- the Volt's computers provided a warning. Many have failed with zero warning and required either an emergency jump (not always successful) or a tow back to the dealer for service. I for one believe that "replace 12 volt battery" should be a GM-recommended service at 42 months in the owners manual - if it hasn't failed by then, it will soon. it can save the owner a lot of grief.
You have 4 years on your trickle-charged battery. I have a 2011, with over 6 years on the original, no trickle charge 12V AGM battery. So I'd say the trickle charge has no effect on the life of the battery.MY2013 and onward trickle charged the 12V while plugged in. I wonder if that reduced the failure rate of those AGM 12V batteries or at least allowed owners to get a few more years out of them? I have a 2013 with 50k miles and still on the original 12v battery.
Same here on my 2011. I also own a 2003 Silverado and it still has the original battery.You have 4 years on your trickle-charged battery. I have a 2011, with over 6 years on the original, no trickle charge 12V AGM battery. So I'd say the trickle charge has no effect on the life of the battery.
