Hi, my "new" 2014 Volt developed a peculiar, faint thumping or rumbling (not a 'clicking') noise from the front end when deaccelerating in L or if braking in D. The car has 44,000 miles on it. The sound was most prominent if slowing while turning right, like into a parking lot, etc.
The dealer said they found excess play in the inner left axle where it exits the transaxle. They said they tried tightening the axle nut(?) but that didn't fix the noise. They escalated it to GM and the engineers consulted with them. They eventually diagnosed the axle itself was worn and needed replacement. GM told the dealer they are seeing more of these inner axle failures on Volts because heavy driving in L puts additional stress and wear on the left axle (tripod joint?) during heavy regeneration, specifically. (i.e. the part may not have been designed robustly enough to accommodate it).
The dealer wanted over $750 to replace the axle, until I gently reminded him it was under warranty....
Has anyone else had this problem?
How much does an OEM brake job cost for a Volt?
