I'm installing a ham radio in my 2017 Volt and purchased a low voltage disconnect box which will start a timer below 12.8 volts and either disconnect the radio after 2 mins or when voltage hits 12.4 volts, whichever comes first. Thinking into this prior to installation, I realized this system is designed for 12v ICE cars with an alternator that continually supplies 13+ volts to charge the battery.
Does anyone know the charging logic of the 12v system in the G2 Volt? Will my voltage ever drop below 12.8 volts while the car is on? If so, any ideas as to protect the battery with the ham radio connected directly to it? I cannot connect it through the fuse panel due to current draw concerns. I'd just hate to accidentally leave it on one day and return to a dead battery.
Thanks!
Thanks!
