1 - 10 of 10 Posts
The bolt connecting the power to my 12v battery was loose, and the 12v battery died. We managed to "jump-start" the car with the help of my wife's AAA call by using the 12v connections under the hood, and then we could unlock the hatch, and do a jump to the battery so the car would start. I probably need a new 12v battery, since at some point, it was down to 5 volts or so. There was a battery service engine check light. The local Chevy dealer was too busy to look at it today. I hope it is safe to drive for a day and a half until I can get it into service.
- Sheldon
Discussion Starter · #2 ·
- Sheldon
I would like to know how to find out what error codes the car sent Onstar...
It may have only been due to the battery draining down from the loose connection. I would tighten it myself and drive it for an hour or so to see if it charges back up and holds unless you have a large battery charger that tells you the amps and volt levels.
It should be safe to drive, but the battery may not work for much longer.
You can pickup a replacement battery from a parts store, and if you have a couple of wrenches, it's pretty straight forward to swap in a new one. Some stores will even do it for you.
Don't discard the 12v. I had a dead 12v in our 2011 Volt at 18 months (Oct 2012) - cause unknown, but something ran it down to dead. Vehicle was unresponsive, so I put a good quality charger on it to bring it back, it took roughly 6 hours to complete the charge. It has been running without issue ever since (6.5 years total).
Just tighten the loose connection, put a good external AGM capable charger on it and you should be fine.
VIN # B0985
Discussion Starter · #7 ·
Should I buy a battery at batteries plus? Or is this something that GM would cover under warranty? Batteries aren't very expensive ....
- Sheldon
This is a 2017? Dealer will fix the loose clamp, test the battery, and send you on your way (assuming it tests ok). Shouldn't be any cost to you.
Should be covered under bumper to bumper since it is a 2017.
· Administrator
Agreed. Do NOT buy a battery. This is a warranty issue.
1 - 10 of 10 Posts
