Hello,
I've had my Volt a couple weeks now and charge it overnight in my detached garage with its own 50A subpanel on a dedicated 15A circuit that has a GFCI receptacle using the charging cord that comes with the car. Twice now I have had my GFCI outlet trip in the middle of the night (after a couple hours of charging), leading to an incomplete charge. I always set my charge to begin immediately. I have never had an error message from the car, and all lights are always green on the charge cord once I restore power. Today I fired everything back up and tripped the GFCI the instant I unplugged the car. That was the first time that's ever happened. The main breaker has never tripped, and there are no other appliances on that line.
I use the same charge cord at work in another GFCI outlet there, outdoors no less, and have not yet had a problem.
I'm leaning toward a problem with the circuit or receptacle itself, but I'm curious how I should proceed.. this is relatively new electrical install (2009), everything was done up to code and fully inspected. Should I try to swap out the GFCI first with a new one and see if it keeps happening? I don't want to replace the outlet with a standard one for safety reasons. Any other ideas on what would cause just the outlet to trip?
