1 - 11 of 11 Posts
The outlet on top of the dash and the outlet in the console are both dead. Fuse right? The fuse is fine. The fuse is not getting power. If I take out the fuse and use a probe it is dead. Is there a relay somewhere that controls power to this part of the fuse box?
Are you booted up? If not they are supposed to be dead.
I would like to have mine live all the time but havn't figured out how yet.
Engine running no power to the 12 volt outlets. I'm just wondering if there is a relay somewhere that controls these two outlets.
Engine running??? Charge the battery. Check for voltage with the EVSE plugged in. Check for voltage after battery is fully charged> These are additional data points in trouble shooting your problem. Please describe your vehicle and mileage.
A frayed wire harness could explain the dead 12V accessory outlets.
Discussion Starter · #7 ·
The engine is fine. The battery is fine. The wiring harness is fine. So it turns out that the 12 volt fuse gets its power from a relay. The dead fuse is on the drivers side of the dash. This fuse box has a spot for 4 relays. On my vehicle only spot one has a relay installed. This relay powers the 12 volt outlets. This relay went bad. If anyone cares it is part #16263 at Autozone. I'm back in business.
Thanks for the update. Glad that everything's back to normal.
Yes, thanks for the update
late to this party
but yes as the car keeps power on for 10 mins aftr shutting off there is a relay ( or very slow electricity )
Glad you found the problem most would not have even found the right fuse ;-)
Happy that your problem has been resolved. It would still be relevant to know the model and mileage to better understand how well the Volt design is holding up...please?
1 - 11 of 11 Posts
